Suppose I have a typical setup/loop style sketch, such as this one which turns on an LED when a button is pressed.
How do I modify this so that it enters low power mode, awakes on the button press, and puts itself back into low power mode when its logic has finished?
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  // desired: enter low power mode here
  int buttonState = digitalRead(buttonPin);
  // desired: awake from low power mode here
  if (buttonState == HIGH) {
    digitalWrite(ledPin, HIGH);
    delay(1000);
    digitalWrite(ledPin, LOW);
  // desired: back to low power mode here
Mark Harrison
  • 559
This sketch is almost identical to the powerDownWakeExternalInterrupt.ino sketch that comes with the LowPower Library. I'm using INPUT_PULLUP and a N.O. push button switch to trigger it to wake up and turn an LED on.
#include "LowPower.h"
const byte wakeUpPin = 2;
// Just a handler for the pin interrupt.
void wakeUp(){}
void setup(){
  // Configure wake up pin as input.
  // This will consumes few uA of current.
  pinMode(wakeUpPin, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
void loop(){
  // Allow wake up pin to trigger interrupt on low.
  attachInterrupt(0, wakeUp, LOW);
  // Enter power down state with ADC and BOD module disabled.
  // Wake up when wake up pin is low.
  LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
  // Disable external pin interrupt on wake up pin.
  detachInterrupt(0);
  // Do something here.
  digitalWrite(LED_BUILTIN, HIGH);
  delay(2000);
VE7JRO
  • 2,515
  • 29
