I have a potentiometer of 10k and I connected it this way:
5v -> potentiometer -> analog input pin of Arduino
When I turn the potentiometer I change the resistance of the circuit but in the Arduino documentation they say that an analog pin in INPUT mode will have 1 megaohm resistance. So, for example, if I turn the potentiometer to the middle it will generate 5k of resistance + 1 megaohm of the analog pin it will result in a tiny, very tiny current. If I use U = R x I across the potentiometer it will be:
U = 5000 x 0.0000001
U ~ 0 across the potentiometer. So U will be 5 V at the analog input because there was no drop of voltage in the circuit. If turn the potentiometer all way up to 10k resistance the voltage in the analog input will also be 5 V because the voltage drop across the potentiometer is still really small.
I know that an analog pin in INPUT mode will read 0 V as 0 and 5 V as 1023. But as I showed you it should always read 5 V even when I turn the potentiometer all way up because the voltage is not being changed. I know I am wrong cause when I log the input pin it shows different values as I turn the potentiometer. So how does this work?
per1234
  • 4,278
  • 43
Samul
  • 215
The potentiometer and the internal resistance form a voltage divider. The voltage created by this voltage divider is essentially indistinguishable from 5V regardless of what the pot is set to because the internal resistance is so high.
What you want to do is to create an external voltage divider that will cause the voltage to vary full scale between 5V and 0V. You do so by connecting one end of the pot to 5V and the other end to 0V, and drawing the voltage from the wiper.
Ignacio Vazquez-Abrams
  • 17,733
  • 28
