I am new to arduino coding. I am reading data from serial port and storing it in char array. I want to send that data to the local server but it is not getting converted to string
Code :
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
ESP8266WebServer server;
char* ssid = "Office RTPL";
char* password = "********";
char data[64];
char data1[64];
String str;
void setup()
  WiFi.begin(ssid,password);
  Serial.begin(115200);
  while(WiFi.status()!= WL_CONNECTED)
    Serial.print(".");
    delay(500);
  Serial.println("");
  Serial.print("IP Address: ");
  Serial.print(WiFi.localIP());
  server.on("/",[](){server.send(200,"text/plain","Data Test");});
  server.on("/toggle",serialData);
  server.begin();
void loop()
  // put your main code here, to run repeatedly:
  server.handleClient();
void serialData()
  if(Serial.available() > 0)
        server.send(200,"text/plain","Data");
         for(int n=0; n<64; n++)
           data[n] = (Serial.read());
         String str (data);
         server.send(200,"text/plain",str);
  else
        String no_data = "No Serial Data";
        server.send(200,"text/plain",no_data);
        delay(5000);
Please help
Juraj
  • 18,264
  • 49
ankit ankit
As I mention in my answer about serial communication:
Before reading, always make sure data is available. For example, this is wrong:
if (Serial.available ())
      char a = Serial.read ();
      char b = Serial.read ();  // may not be available
The Serial.available test only ensures you have one byte available, however the code tries to read two. It may work, if there are two bytes in the buffer, if not you will get -1 returned which will look like 'ΓΏ' if printed.
In your code:
So you know that one byte is available, but you are reading 64. No, that won't work.
Nick Gammon
  • 38,901
