With an Arduino-like board using a CH340 USB Serial chip, I'd like to send text lines as fast as possible to a Raspberry Pi through USB using the Serial.println() function. The problem is that when I set the serial speed to values above 230 400 with the Serial.begin(speed) function, the Arduino console crashes and the C program on the Rapsberry Pi displays garbage in its console, even though I set the same serial speed.
Short examples :
Serial.begin(230400);
Serial.println("Test !"); // Works fine.
Serial.begin(250000);     // Or any speed above 250 000.
Serial.println("Test !"); // Doesn't work at all.
This answered question states that 2 Mbauds is possible, so I'm a bit lost.
The Arduino IDE console offers various speed from 300 to 2 000 000 bauds, so why don't speeds above 230 400 work ?
Chris Stratton
  • 5,411
  • 40
Thesaurus Rex
  • 63
CHG340 supports common baud rates: 50, 75, 100, 110, 134.5, 150, 300, 600, 900, 1200, 1800, 2400, 3600, 4800, 9600, 14400, 19200, 28800, 33600, 38400, 56000, 57600, 76800, 115200, 128000, 153600, 230400, 460800, 921600, 1500000, 2000000 baud.
250 000 baud isn't supported by that IC.
The Baud steps is either 200% or 150% of the previous value (There is exceptions).
Tested and working Baud rates.
I used putty as serial monitor since the built in monitor didn't have all baud rates preprogrammed.
SpeedTest.ino
// Serial port Baudrates:
// const int Speed = 115200;
// const int Speed = 128000;
// const int Speed = 153600;
// const int Speed = 230400;
// const int Speed = 460800;
// const int Speed = 921600;
// const int Speed = 1500000;
const int Speed = 2000000;
  // Initialize serial:
  Serial.begin(Speed);
  // Initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  delay(1000);
  digitalWrite(LED_BUILTIN, LOW);
  delay(1000);
  Serial.print("Speed :  ");
  Serial.println(Speed);
MatsK
  • 1,366
There may just be a workaround to allow this adapter to operate at 250000 baud (at least in the Raspberry Pi). The author of this article: http://dmxpi.blogspot.com/2014/04/dmx-on-raspberry-pi-start-here.html has modified the linux driver and claims it works. I hope this helps.
