Yesterday I wrote in a comment that I didn't break much, except a LED and a LED matrix. However, exactly yesterday I think my Uno gave up, since I cannot upload a sketch anymore (timeouts). For the rest the board seems to work still ok.
I have two possible reasons, and would like to know what I can do to prevent this in future. I connected a 415 MHz RF transmitter and receiver to it, which are working.
  1. To get more power I attached an adapter (12V), TOGETHER with the USB ... I thought always adapter power would be used, but it seems it is not a good idea to have both connected. Is this true?
  2. The Uno was inside a case (with holes near the output pins). I know this causes some extra heat, but I would guess that adding just an RF receiver/transmitter would not cause the Uno to heat up more than allowed.
Which of these reasons is the possible cause ... or are there any other reasons I didn't think off. Everything worked fine until I plugged in the 12V adapter and it still worked for some time (until I tried to upload a new sketch).
Michel Keijzers
  • 13,014
  • 41
  • 58
You should be OK as long as you use a 9 to 12 volt supply since there is an FET that disconnects the 5 volt USB power from the rest of the Arduino circuitry if VIN is greater than approximately 6.6 volts.
But... if your external voltage is less than 6.6 volts you may have a problem since both supplies will be powering the Arduino circuitry and they probably will not be providing exactly the same voltage. If you get below the dropout voltage of the voltage regulator then you may have a bigger problem since the USB voltage will be backfeeding the voltage regulator.
There is a diode between the PWRIN connector and VIN so if you feed the Arduino from that connector the voltage will have to be greater than approximately 7.3 volts to activate the FET and anything less than 7.3 volts may cause the problems mentioned above.
Sonali_B
  • 443
It is a mistaken belief that powering an Arduino from an external power source increases the power available. It doesn't. All it does is increase the amount of heat produced.
Unless you are powering your Arduino from an unpowered hub you will have around 500mA available from the USB power. The 5V regulator, which converts the incoming 12V to 5V, can supply at best between 800mA and 1A on a good day. However with 12V the amount of heat generated will cause thermal shutdown at those kind of currents due to lack of proper heatsinking. So you can't get anywhere near 800mA out of it - instead you are limited to around the same as (or even less than) the USB power source can provide.
All that excess heat (and at 12V you are throwing away about 58% of your power as heat) in an enclosed case will have caused nasty things to happen - at the very least your regulator should have gone into thermal shutdown. Worst case scenario your voltage regulator failed (especially if it's a cheap version) which would end with one of two scenarios:
  1. No power getting through to the rest of the board
  2. More than 5V getting through to the rest of the board
If it's (1) it'd be obvious - nothing works. No LEDs light, etc. However if it's (2) then more nasty things will ensue. One common one is that the ATMega16U2 chip (the USB interface chip) if it's a genuine Arduino will be fried. You may find it's getting excessively hot itself now. Of course, if it's a clone then the CH340G will no doubt have given up what little ghost it had.
Majenko
  • 105,851
  • 82
  • 139
