15
The uno has digital pins marked 0-13.
0 is marked as rx and 1 is marked as tx. Can these two pins be used as regular digital pins if i am short of digital pins?
c_breeez
  • 349
Yes you can perfectly use these 2 pins as long as your program does not use Serial.
EDIT: Serial data over USB goes through copper traces connected to the rx and tx pins, connecting them to the USB to serial converter chip.
jfpoilpret
  • 9,162
  • 38
  • 54
Also you will probably want to ensure these wires are not connected when programming the Arduino. Otherwise you may have problems.
sdcharle
  • 131
You can, but it will disable the serial port.
