I have a simple library which uses another library.
Here is the header:
#ifndef __DERIVEDCLASS_H__
#define __DERIVEDCLASS_H__
#include <HardwareSerial.h>
class DerivedClass
private:
    HardwareSerial* serial;
public:
    DerivedClass();
#endif
And the CPP:
#include "DerivedClass.h"
DerivedClass::DerivedClass()
And the sketch:
#include <DerivedClass.h>
void setup()
void loop()
This works fine.
However, if I change the library header to this:
#include <SoftwareSerial.h>
class DerivedClass
private:
    SoftwareSerial* serial;
public:
    DerivedClass();
#endif
The sketch fails to compile:
/Users/andrew/Documents/Arduino/libraries/DerivedClass/DerivedClass.h:9: error: ISO C++ forbids declaration of 'SoftwareSerial' with no type /Users/andrew/Documents/Arduino/libraries/DerivedClass/DerivedClass.h:9: error: expected ';' before '*' token
If I change the sketch to:
void setup()
void loop()
i.e. including the SoftwareSerial library in the top level sketch, it compiles fine.
If I expand the library out so it actually performs actions, then if it compiles, it works.
Why is this? HardwareSerial is a built-in part of the Arduino, located in hardware/arduino/cores/arduino and SoftwareSerial is in libraries, but why would the build process differentiate between the two.
Cybergibbons
  • 5,420
  • 34
If I remember correctly this is in fact a limitation of the Arduino IDE.
If you use a better IDE (personally I use Eclipse with the Arduino plugin) it works as it should, i.e. if you include a library A that includes another library B, then in the end you won't get compile-time errors and both B and A will be included in the final binary.
jfpoilpret
  • 9,162
  • 38
  • 54
