A commonly used library is the DallasTemperature library, used to access DS18B20 sensors on a 1-Wire bus. When creating a DallasTemperature object you pass a reference to a OneWire object. OneWire can create a 1-Wire bus on pretty much any port of an Arduino.
An example of this is like so:
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
However, there are some issues with using OneWire to drive a 1-Wire bus, mainly around driving longer bus lengths, dealing with shorts, and other errors.
There is a commonly available chip called the DS2482-100 that can drive longer busses (hundreds of feet), deals with shorts and other errors. It is also less CPU heavy and it deals with a number of the slower aspects of 1-Wire.
For this reason, I would like to be able to pass a reference to a library that I have created instead. Currently, I am doing this by:
  • Calling the library OneWire
  • Replicating all the methods called by the DallasTemperature library
  • Swapping out the OneWire library for mine
This is relatively messy. I would ideally like to be able to pass either a reference to my library or a 1-Wire library, so that people can chose which interface to use.
How would I go about doing this?
Cybergibbons
  • 5,420
  • 34
The typical way to achieve what you want would normally be to create your own subclass of OneWire class and override the methods you need to change, then pass a pointer to an instance of your class to the DallasTemperature constructor.
However, for this to work, the OneWire class must have been developed with extensibility (subclassing) in mind, i.e. use virtual methods that you can override.
Unfortunately, a quick look at OneWire.h shows that no method is virtual in there.
So that means in the end you will have to perform some hacks, just as you do now.
What you could potentially do (that's still a hack, but maybe a bit less dirty) is:
  • replace OneWire.h to make all methods virtual (at least those you need to override)
  • keep the original OneWire.cpp that should still compile with the newly adapted header file
  • create a new MyOneWire.h / MyOneWire.cpp to define your own OneWire subclass that overrides all necessary methods as you want
Then you can pass either a OneWire or a MyOneWire instance to DallasTemperature constructor.
NB: when I see my answer, this makes me think your question is more a general C++ question than an Arduino-related one.
jfpoilpret
  • 9,162
  • 38
  • 54
The DS2482-100 is an I2C-to-1-Wire®bridge device that interfaces directly to standard (100kHz max) or fast (400kHz max) I2C masters to perform bidirectional protocol conversion between the I2C master and any downstream 1-Wire slave devices.
It uses a higher level protocol over I2C which does not directly match the bit-banged OneWire interface above.
A possible solution is to "only" reuse the OneWire interface and reimplement it. Sub-classing will not work as the member functions are not virtual. Unfortunately this will not work directly due to error handing, timing, etc. The DallasTemperature class will also need modifying.
Please see the DS2482-100 product description and protocol.
To achieve your goal of allowing either bit-banged or DS2482-100 based 1-Wire master would require 1) an abstract interface (class) used by 1-Wire master device drivers, 2) sub-classes for each implementation master variant.
As the 1-Wire protocol has a number of common commands a delegation pattern is more useful. Please see the Cosa OWI::Driver and DS18B20 device driver for an example of the delegation pattern.
Mikael Patel
  • 7,989
