12
Inside my main loop there is this string:
String string1;
I have a function that will take string1 as parameter, and use it to send this string as SMS.
sendSMS(string1);
This is the sendSMS() function (without parameters):
void sendSMS()
{ sms.beginSMS(remoteNumber);
  sms.print(finalstr);
  sms.endSMS();
  lcd.setCursor(0, 0);
  lcd.print("Message sent!");
  delay(10000);
My questions are:
  1. How do I put the string input parameter in sendSMS?
  2. Do I also need to use a function prototype for sendSMS()? (so that it appears three times, 1 in the prototype, 1 in the declaration and one in the call). Or I don't need to use function prototype before the main loop()?
The Guy with The Hat
  • 5,292
  • 30
user1584421
  • 1,425
  • 26
  • 36
  1. Just change
    void sendSMS()
    to
    void sendSMS(const String& thisIsAString)
    You can then access the parameter inside the function with thisIsAString.
  2. No, you do not need a prototype.
  • 5,292
  • 30
I'd say to never use String again. When code gets bigger and memory usage will be critical you'll hit a dead-end. I know it's more convenient, but give char arrays a shot. Something like:
bool sendSMS(int remoteNumber, char *finalstr){
  bool isFinished = 0;
  for (int i=0;i<sizeof(finalstr);i++){
  sms.endSMS();
  delay(10000);
  isFinished = 1;
  return isFinished;
I changed the function to bool. It means that you can use it inside an if statement, where you would want it completed before continuing with your code.
You will need to allocate memory yourself for the array; declare it like this:
char stringArray[33] = {'\0'};
Here, I allocate 32 bytes for data and one additional byte for the character that means "end of string" (it's that \0).
dBm
  • 115
You can change
void sendSMS()
to
void sendSMS(String myinputstring)
you can use myinputstring in your code.
