I know that menus were discussed perhaps a thousand times here and everywhere. But using a ready solution is not something that I'm looking for because I know I won't learn the concept if I use them. Hence the question.
I am trying to build a simple timer with a setup menu. The timer code works so that part of the code is not a problem. The menu is an adaption of a code I found online which I understand, and for the most part, works as long as I am in level 1. My menu will have 2 levels. the structure of the menu is something like this:
Option 1: Display Timer 1
Option 2: Display Timer 2
Option 3: Reset Timer 1
Option 4: Reset Timer 2
Option 5: Set Timer 1 Action Delay
  • Option 5.1: Delay01
  • Option 5.2: Delay02
  • Option 5.3: Delay03
  • Option 5.4: Back
Option 6: Set Timer 2 Action Delay
  • Option 6.1: Delay01
  • Option 6.2: Delay02
  • Option 6.3: Delay03
  • Option 6.4: Back
The menu will be displayed with an I2C 1602 LCD Screen, and navigation will be by way of 3 push buttons: Up, Down, and Select.
I am using a nested "switch case" statement to navigate between the menus.
So as long as I'm in level 1, everything works. the times are displayed, reset works, and all is well. The moment I go to a submenu, the first option in the submenu is selected immediately and the display shows the parent menu.
I am putting the menu code in a function, the submenu code in another function. Once the menu with a submenu is selected, it calls the submenu function.
My current code is as follows: [Note: Updated with a function to handle screen updates based on @jsotola]
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#include <EEPROM.h>     //EEPROM Functions: EEPROM Module
#include <Arduino.h>    //EEPROM Functions: for type definitions
LiquidCrystal_I2C lcd(0x27,16,2);
//Globals:
int page_counter    =   1 ; //To move between pages
int page_counter_s  =   1;  //submenu
int up = 2;             //Up button
int down = 3;           //Down button
int selection = 4;      //Select button
int LED =   13;
int pageCount   =   7;  //Main Menu
//Main Menu
boolean last_up         =   LOW;
boolean last_down       =   LOW;
boolean last_select     =   LOW;
boolean current_up      =   LOW;
boolean current_down    =   LOW;
boolean current_select  =   LOW;
boolean last_up_s     =   LOW;
boolean last_down_s     =   LOW;
boolean current_up_s    =   LOW;
boolean current_down_s  =   LOW;
String line1;
String line2;
//---- De-bouncing function for all buttons----//
boolean debounce(boolean last, int pin){
  boolean current = digitalRead(pin);
  if (last != current){
    delay(5);
  return current;
//LCD Function
void printlcd(){
    lcd.setCursor(0,0);
    lcd.print(line1);
    lcd.setCursor(0,1);
    lcd.print(line2);
//Menu Function
void Menus(){
    current_up = debounce(last_up, up);         //Debounce for Up button
    current_down = debounce(last_down, down);   //Debounce for Down button
    current_select = debounce(last_select, selection); //Debounce for Select button
    //----Page counter function to move pages----//
        //Page Up
        if (last_up == LOW && current_up == HIGH){  //When up button is pressed
          lcd.clear();                     //When page is changed, lcd clear to print new page
            if(page_counter < pageCount){             //Page counter never higher than 3(total of pages)
                page_counter= page_counter +1;   //Page up
            else{
                page_counter = pageCount;
        last_up = current_up;
        //Page Down
        if (last_down== LOW && current_down == HIGH){ //When down button is pressed
          if(page_counter >1){              //Page counter never lower than 1 (total of pages)
          page_counter= page_counter -1;   //Page down
          else{
          page_counter= 1;
        last_down = current_down;
//------- Switch function to write and show what you want---//
  switch (page_counter) {
    case 1:{ //Each case is a menu option
      line1 = "Counter 01:";
      line2 = "100 Hrs";
      printlcd();
    break;
    case 2:{ //Each case is a menu option
      line1 = "Counter 02:";
      line2 = "70 Hrs";
      printlcd();
    break;
    case 3:{ //Each case is a menu option
      line1 = "Reset 01:";
      line2 = "";
      printlcd();
      //Action:
      if (last_select == LOW && current_select == HIGH){ //When down button is pressed
            lcd.clear();
            line1 = "Success!";
            line2 = "C01 Reset";
            printlcd();
            digitalWrite(LED,HIGH);
            delay(500);
            digitalWrite(LED,LOW);
            delay(3000);
            lcd.clear();
    break;
    case 4:{ //Each case is a menu option
      line1 = "Reset 02:";
      line2 = "";
      printlcd();
      //Action:
            lcd.clear();
            line1 = "Success!";
            line2 = "C02 Reset";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
    case 5:{ //Each case is a menu option
        line1 = "Set 01";
        line2 = "Interval";
        printlcd();
      //Action:
            lcd.clear();
            submenu();
    break;
    case 6:{ //Each case is a menu option
        line1 = "Set 02";
        line2 = "Interval";
        printlcd();
      //Action:
            lcd.clear();
            submenu();
    case 7:{ //Each case is a menu option
        line1 = "Exit service";
        line2 = "mode";
        printlcd();
      //Action:
            lcd.clear();
            line1 = "Exiting";
            line2 = "Please Wait";
            printlcd();
            delay(500);
            delay(500);
            delay(3000);
            lcd.clear();
    break;
  }//switch end
void submenu(){
    current_up_s = debounce(last_up, up);         //Debounce for Up button
    current_down_s = debounce(last_down, down);   //Debounce for Down button
        //Page Up
        if (last_up == LOW && current_up_s == HIGH){  //When up button is pressed
            if(page_counter_s < 8){             //Page counter never higher than 3(total of pages)
                page_counter_s = page_counter_s +1;   //Page up
            else{
                page_counter_s = 8;
        last_up = current_up_s;
        //Page Down
        if (last_down == LOW && current_down_s == HIGH){ //When down button is pressed
          page_counter_s = page_counter_s -1;   //Page down
          else{
          page_counter_s = 1;
        last_down = current_down_s;
  switch (page_counter_s) {
      line1 =   "Set dealy to:";
      line2 =   "100 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line1 = "New Delay:";;
            line2 = "100 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "200 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "200 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "300 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "300 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "400 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "400 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "500 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "500 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "600 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "600 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
      line2 =   "700 hrs";
      printlcd();
      //Action:
            lcd.clear();
            line2 = "700 hrs";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
    case 8:{ //Each case is a menu option
      line1 =   "Back";
      line2 =   "";
      printlcd();
      //Action:
            lcd.clear();
            line1 = "Returning";
            line2 = "";
            printlcd();
            delay(500);
            delay(3000);
            lcd.clear();
    break;
  }//switch end
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("Menu Test");
  delay(3000);
  lcd.clear();
  Menus();
So, my first question is: What is going wrong with the submenu? and my second question is: in the submenu, how do I exit back to main menu?
Any assistance will be much appreciated.
Thank You.
Michel Keijzers
  • 13,014
  • 41
  • 58
MDChaara
  • 207
