If I remove the transmission code from slave this works properly but I need to transmit from slave.
Here is my master code
#include <Wire.h>
  Wire.begin(3);
  Wire.onReceive(receiveEvent);
byte x = 0;
  Wire.beginTransmission(9);
  Wire.write("s");
  Wire.write(x);
  Wire.endTransmission();
  x++;
  delay(500);
void receiveEvent(int howMany) {
  if(Wire.available()){
    int x = Wire.read();
    Serial.println(x);
Here is my slave code:
#include <Wire.h>
  Wire.begin(9);                // join i2c bus with address #9
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  delay(100);
    char c = Wire.read();
    Serial.print(c);
    if(c == 's'){
      Serial.println(x);
      //transmit to master
      Wire.beginTransmission(3);
      Wire.write(1);
    } else {
      Wire.read();
Is it possible not to use Wire.onRequest(requestCallback); to send data to master? Kindly help.
dda
  • 1,595
srinivas
  • 83
To join the bus as a master you cannot supply a 7-Bit slave address so your code has two slaves.
Below you will find 2 sketches that successfully sends data to a slave. I would suggest you start looking at the I2C protocol and understand there are 4 Modes:
  • Master->Transmitter
  • Master->Receiver
  • Slave->Transmitter
  • Slave->Receiver
All communications regardless of how the data is transferred requires a master. It's the master that controls the clock pulses, thats why its always the master that initiates the communcation.
The MasterReader/MasterWriter tutorials on the arduino forum should now possibly start to make a little more sense when understanding those modes.
This code shows how a master sends data to a slave, and then how it requests data from the slave. If we look at this code from the master point-of-view, you can see it essentially says, send this byte to the client (m->t & s->r), then request data from the slave (m->r,s->t)
Master Code
#include <Wire.h>
#define SLAVE_ADDRESS 0x60
void setup()
  Wire.begin();
  randomSeed(analogRead(3));
  Serial.begin(9600);
byte x = 0;
void loop()
  x = random(0,255);
  Serial.print("Sent: ");
  Serial.print(x, HEX);
  Serial.print("\n");
  Wire.beginTransmission(0x60);
  Wire.write(x);
  delay(500);
  Serial.println("Requesting Data");
  Wire.requestFrom(SLAVE_ADDRESS, 1);
  int bytes = Wire.available();
  Serial.print("Slave sent ");
  Serial.print(bytes);
  Serial.print(" of information\n");
  for(int i = 0; i< bytes; i++)
    x = Wire.read();
    Serial.print("Slave Sent: ");
    Serial.print("\n");
  delay(500);
Slave Code
#include <Wire.h>
byte x = 0x00;
void setup()
  Wire.begin(SLAVE_ADDRESS);
  Wire.onRequest(requestEvent);
  Serial.begin(9600);
void loop()
  delay(100);
void requestEvent()
  Serial.print("Request from Master. Sending: ");
  Serial.print("\n");
  Wire.write(x);
void receiveEvent(int bytes)
  if(Wire.available() != 0)
      x = Wire.read();
      Serial.print("Received: ");
      Serial.print("\n");
Wayne
  • 161
I went through this problem recently. Your slave needs two functions: one for sending and the other for receiving data.
// function: what to do when asked for data
void requestEvent() {
Wire.write(t);
// what to do when receiving data from master
{Val = Wire.read();}
Here is a code that works both ways of i2c communication in a single code
Sending and receiving different types of data via I2C in Arduino
Camilo
  • 359
You had:
           Serial.print(c);
           if(c == 's'){
             Serial.println(x);
             Wire.write(1);
           }else{
             Wire.read();
There are a number of problems with your slave code.
  1. Don't do Serial prints in an ISR (interrupt service routine)
  2. Don't do beginTransmission / endTransmission in a receive event.
  3. Don't do any writes
  4. To send data back use a requestEvent not a receiveEvent.
Better would be:
// add in setup()
Wire.onRequest (requestEvent);  // interrupt handler for when data is wanted
volatile byte what;
  if (howMany < 2)
    return;
  char c = Wire.read ();
  if (c != 's')
    return;
  what = Wire.read ();  // remember what we got
}  // end of receiveEvent
void requestEvent()
  Wire.write (1);  // return a response
}  // end of requestEvent
the Wire.requestFrom has only one Wire.write. I need multiple Wire.write which is not supported so are there any workarounds?
Batch up the response and do one write:
void requestEvent ()
  byte buf [4] = { 1, 2, 3, 4 };
  Wire.write (buf, sizeof buf);   // send response
Reference
There are a lot of examples at I2C - Two-Wire Peripheral Interface - for Arduino
Nick Gammon
  • 38,901
