I have found a few good tutorials on how to send and receive data via I2C in connected arduinos. My limitation is now how to transmit different types of data like for instance, long, float, etc. Right now the communication via I2C using the wire library only allows transmission of numbers between 0 and 255. How can one transmit different types of numbers?.
In my code a master receives three types of data from the slave, and it send data of a fourth variable to the slave.
here is the code for the master
#include <Wire.h>
const int SLAVE_ADDRESS = 8; //Slave arduino ID
int table[]={0,0,0}; //the data will be transmited via table as to allow different data to be transfer.
void setup ()
Wire.begin ();
Serial.begin (9600);  // start serial for output
}  // end of setup
void loop()
Wire.requestFrom(SLAVE_ADDRESS, 3);// request 3 bytes from slave device #8
for(int i=0;i<3;i++)//organizes the data from the slave in the table
int c = Wire.read(); // receive a byte as character
table[i]=c;
//displays the data
 Serial.print('\n');
   Serial.print(table[0]);
    Serial.print('\t');
   Serial.print(table[1]);
    Serial.print('\t');
   Serial.print(table[2]);
   Serial.print('\n');
delay (500);
// transmit just this variable to the slave
int Work=1;
Wire.beginTransmission (8);
Wire.write (Work);
Wire.endTransmission ();
here is the code for the slave
#include <Wire.h>
int Work=0;
Wire.begin(8);                // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
Wire.onReceive(receiveEvent); // register event
int x=120;
int y=1200;// gets converted to an strange # because is larger than 255
int z=3;
  table[0]=x;
  table[1]=y;
  table[2]=z;
void requestEvent()
  uint8_t Buffer[3];
  Buffer[0]=table[0];
  Buffer[1]=table[1];
  Buffer[2]=table[2];
  Wire.write(Buffer,3);
void receiveEvent(int howMany)
{Work = Wire.read();}
Camilo
  • 359
I2C is truly a powerful option of Arduino, for too many reasons; yet the amount of tutorials available are not that many and unfortunately are too complicated for the average person.
After working on this for 2 days, I think I have a way to transfer pretty much anything between master and slaves and viceversa. Note that I2C does not transfer floats or even integers larger than 255, there are several ways to go about this and here is a good tutorial http://www.gammon.com.au/i2c and even a library: http://forum.arduino.cc/index.php?topic=171682.0
The solution I found was simpler. Basically we convert any value, string, number, text, float, you name it, and turn into a variable char, which can be transferred via I2C. Once transferred, you can convert back to a number although in my case below, I just wanted to display the data from the slave.
Here is the code. I provide comments on different parts for clarity. I hope this helps. it worked for me.
//master
#include <Wire.h>
char t[10]={};//empty array where to put the numbers comming from the slave
volatile int Val; // varaible used by the master to sent data to the slave
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.requestFrom(8, 3);    // request 3 bytes from slave device #8
//gathers data comming from slave
int i=0; //counter for each bite as it arrives
  while (Wire.available()) {
    t[i] = Wire.read(); // every character that arrives it put in order in the empty array "t"
    i=i+1;
Serial.println(t);   //shows the data in the array t
delay(500); //give some time to relax
// send data to slave. here I am just sending the number 2
  Val=2;
  Wire.write (Val);
here the other part //slave
#include <Wire.h>
char t[10]; //empty array where to put the numbers going to the master
volatile int Val; // variable used by the master to sent data to the slave
  Wire.begin(8);                // Slave id #8
  Wire.onRequest(requestEvent); // fucntion to run when asking for data
  Wire.onReceive(receiveEvent); // what to do when receiving data
  Serial.begin(9600);  // serial for displaying data on your screen
  int aRead = analogRead(A0); //plug a potentiometer or a resistor to pin A0, so you can see data being transfer
  float x = aRead/1024.0*5.0; //generate a float number, with this method you can use any time of data pretty much
  dtostrf(x, 3, 2, t); //convers the float or integer to a string. (floatVar, minStringWidthIncDecimalPoint, numVarsAfterDecimal, empty array);
  Serial.println(Val);         // print the character
 delay(500);
// function: what to do when asked for data
void requestEvent() {
Wire.write(t);
// what to do when receiving data from master
{Val = Wire.read();}
Camilo
  • 359
I believe that for your scenario, i.e. sending different types of variables, the EasyTransfer library (by Bill Porter) would be an elegant solution. The library can be found here: https://github.com/madsci1016/Arduino-EasyTransfer. There are implementations for serial, I2C, and VirtualWire and the examples provided are pretty self-explanatory.
The handling is very easy. After including the library, you create an EasyTransfer object, define a data structure that basically represents a "container" of your data and this can consist of different variables.
struct RECEIVE_DATA_STRUCTURE{
  //put your variable definitions here for the data you want to receive
  //THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
  int blinks;
  int pause;
Once the "container" is filled, i.e. the variables are set on the sender side, they are sent with a simple command
  ET.sendData(I2C_SLAVE_ADDRESS);
On the receiver side, you define an identiacl data structureand receive the data by
ET.receiveData();
Hope this helps.
hobie
  • 487
Use the 'I2C_Anything' library, available here. I use it in all my I2C projects. It is extremely simple and works great. Here's the entire .h file
// Written by Nick Gammon
// May 2012
#include <Arduino.h> #include <Wire.h>
template <typename T> unsigned int I2C_writeAnything (const T& value) { Wire.write((byte *) &value, sizeof (value)); return sizeof (value); } // end of I2C_writeAnything
template <typename T> unsigned int I2C_readAnything(T& value) { byte * p = (byte) &value; unsigned int i; for (i = 0; i < sizeof value; i++) p++ = Wire.read(); return i; } // end of I2C_readAnything
starship15
  • 782
