-2
I have an unofficial Arduino Uno.
I've tested these:
  • Testing on USB 2.0 and USB 3.0
  • Changing Port (COM XX)
  • Updating drivers for the Unknown device to Arduino Uno (COM XX)
  • Resetting Arduino Board
  • Plug/Unplug
  • 1x PC Reboot
  • Burning bootloader
  • Changing 'Programmer'
  • Uninstalling-Reinstalling device
  • Holding the "Reset" button while I Upload
  • Testing different examples (Blinking/Voltage Serial Read)
  • Testing different "Board" in Arduino software (just in case, you never know)
  • Removing jump wires
Does anyone have any suggestion more than I just tried?
VE7JRO
  • 2,515
  • 29
Eksapsy
  • 99
The board you have uses the CH340G chip instead of an ATMega16U2 or FTDI FT232R chip.
It requires special drivers, not the ones that come with the IDE.
Why do they use that chip instead of the proper one? Simply because it's dirt cheap. They are the cheapest of the cheapest of the cheapest USB chips around. They frequently die. You might want to save up and invest in a genuine Arduino at some point, because that one may well die out of the blue.
Majenko
  • 105,851
  • 82
  • 139
I had the same problem with the cheap nano from Amazon Longrunner. At first, it worked, I could program it. Then, I farted around with my COM port numbers because I was tired of being in the COM14 area. Since that moment, it stopped working. IDE couldn't find the port COM3. After reading you guys, I also noticed that the device was identified RAMPS which it wasn't before. I updated the driver which didn't work; it told me I was already with latest driver. So I deleted that driver and reconnected my Nano and lord and behold, the new driver USB-SERIAL CH340 installed and everything was fine. El cheapo still works. I don't care to pay more just for the USB chip which I will use only once. The uP is still up to par.
Brew
I had the same problem. I was able to upload a simple Blink example, but not my own program. And I thought there's no problem in my program, since I successfully tested it on other Arduino before. But actually, that was the problem. I had this in my program (for console logs):
  Serial.begin(9600);
Then I read that different Arduinos use different baud rates. Originally I tested it on Arduino Mega, but this time I wanted to upload it to "unofficial" Arduino Nano (for which you have to use ATmega328P (Old Bootloader) option when uploading).
Since I didn't need debug logs in my program anymore, I removed these 'Serial' commands completely. Then it got uploaded without problems.
A short article on this topic
juice
  • 119
