I bought this Chinese Arduino Mega 2560 16AU.
This was the first time to deal with Arduino boards. When I try to upload a sketch I always get this error:
stk500v2_getsync(): timeout communicating with programmer
I successfully burnt a bootloader to it using an Arduino uno,
but the same error is there.
Finally I discovered the the loop test is not working, and only the LX LED flashes once when I enter a letter in the serial monitor.
Ricardo
  • 3,390
  • 26
  • 55
user22946
It's our old friend the CH340G again, isn't it?
You've been sold a dud, I'm afraid. The USB chip used there is dead. It happens a lot with those cheap Chinese boards. You should still be able to use the board with an external FTDI adapter by wiring it in to TX->RX, RX->TX and DTR->RESET (via a 100nF capacitor) with power and ground connected of course.
There is also a slim chance that the CH340G may interfere with the TX/RX pins, in which case you may need to remove it. Simply cutting the pins on it with an xacto knife then removing the stumps with a soldering iron and tweezers would do the job.
Majenko
  • 105,851
  • 82
  • 139
If You Downloaded the driver it should be fine!
https://github.com/jimaobian/CH34x_Install_V1.3
Sergei Glimis
  • 149
