The concept:
Play a sine wave saved as a character array in PROGMEM through an 8-bit DAC connected to the PORTC pins on the Arduino Mega.
This works:
// File just defines an array and a size
#include "sine440.h"
int i = 0;
DDRC = B11111111;
PORTC = pgm_read_byte(&sine[i++]);
if(i >= sine_size){
i = i - sine_size;
delayMicroseconds(60);
The above code produces a sine wave of about 440 Hz, exactly what I wanted. Now, I'd like to move this into an interrupt routine, as follows:
This doesn't work
int i = 0;
DDRC = B11111111;
TCCR5B = (1 << WGM52) | (1 << CS50 );
OCR5A = 16000000/16000;
TIMSK5 = (1 << OCIE5A);
ISR(TIMER5_COMPA_vect){
if(i >= sine_size){
i = i - sine_size;
The above code produces a sine wave of 1721 Hz. I know that this means it's iterating through the array too fast, but I don't know how to change it. In order for it to produce 440 Hz, it needs to be preforming 16,000 iterations per second, which is what I believe OCR5A = 16000000/16000; does. But it doesn't appear that changing the value of OCR5A does anything at all. Giving it the max value of 65,535 still produces a 1721 Hz sine wave...
So what am I doing wrong here? How do I change the speed of this timer interrupt?
