I would like to use three timers in CTC mode to launch three Interrupt Service Routines at different frequencies.
In this application I need to use the servo library, millis() and micros() functions.
Timer3 (Working)
Thanks to this question, Timer3 has been set up in the following way:
  cli();          // disable global interrupts
  TCCR3A = 0;     // set entire TCCR3A register to 0
  TCCR3B = 0;     // same for TCCR3B
  // set compare match register to desired timer count:  @~744 Hz
  OCR3A = 20;
  // turn on CTC mode:
  TCCR3B |= (1 << WGM32);
  // Set CS10 and CS12 bits for 1024 prescaler:
  TCCR3B |= (1 << CS30) | (1 << CS32);
  // enable timer compare interrupt:
  TIMSK3 |= (1 << OCIE3B);
  // enable global interrupts:
  sei();
  ISR(TIMER3_COMPB_vect)
     cont++;
Timer4 I've tried with this configuration:
TCCR4A = 0;     // set entire TCCR3A register to 0
TCCR4B = 0;     // same for TCCR3B
// set compare match register to desired timer count: @ ~744 Hz
OCR4A = 20;
TCCR4B |= (1 << WGM42);
TCCR4B |= (1 << CS40) | (1 << CS42);
TIMSK4 |= (1 << OCIE4B);
//TIMSK4 |= (1 << OCIE4A); same issue
sei();
ISR(TIMER4_COMPB_vect) //TIMER4_COMPA_vect same issue
  cont++;
But the compiler returns an error caused by the servo library conflict:
Servo\Servo.cpp.o: In function '__vector_42': C:\Program Files (x86)\Arduino\libraries\Servo/Servo.cpp:117: multiple definition of '__vector_42' Timer4B_800Hz.cpp.o:C:\Program Files (x86)\Arduino/Timer4B_800Hz.ino:49: first defined here c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
As Gerben suggested in a comment in this question:
They are just hogging all timers. I guess you have to alter the library slightly by removing the #define _useTimer3 line, or try putting a #undef _useTimer3 right after the include. – Gerben
I would avoid changing the servo library since motors play a critcal role in the application.
Timer 5 Same issue
Which timers and output compare registers can I use to set up the three ISR correctly?
UserK
  • 559
The problem is the Servo library. This library is claiming all the timers, so you can't use them yourself. What I do to fix this is edit the Servo.h (or ServoTimers.h) file.
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
//#define _useTimer5
#define _useTimer1
#define _useTimer3
//#define _useTimer4
//typedef enum { _timer5, _timer1, _timer3, _timer4, _Nbr_16timers }   timer16_Sequence_t;
typedef enum { _timer1, _timer3, _Nbr_16timers } timer16_Sequence_t;
This will remove the 2 timers (4 and 5) for the Mega boards, but you can still attach 24 servo's. If you need more, you should edit this file again.
Sven
  • 221
