I have a header file called Rhino.h with class Rhino. I want to pass RX and TX pin numbers to this object class, and with this, define a SoftwareSerial object to be used inside the Rhino class. The code in my header file looks like this (there are more number of functions like gotoPos() which I have omitted for brevity purpose):
#include "Arduino.h"
class Rhino
public:
Rhino(int rx,int tx):serial(rx,tx){}
void gotoPos(int pos)
serial.write(pos);
private:
SoftwareSerial serial;
And my Arduino code looks like this:
#include <Rhino.h>
Rhino motor1(9,10);
void setup()
motor1.gotoPos(10);
void loop() {}
I get this as error:
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Uno"
S:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IS:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IS:\Program Files (x86)\Arduino\hardware\arduino\variants\standard -IS:\Program Files (x86)\Arduino\libraries\Rhino C:\Users\Samvrit\AppData\Local\Temp\build2516495983752907071.tmp\Test2.cpp -o C:\Users\Samvrit\AppData\Local\Temp\build2516495983752907071.tmp\Test2.cpp.o
In file included from Test2.ino:6:
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:740: error: 'SoftwareSerial' does not name a type
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In constructor 'Rhino::Rhino(int, int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:16: error: class 'Rhino' does not have any field named 'serial'
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::init()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:21: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::reset()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:30: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::autoCalibrate()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:37: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::sendCmd(String)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:46: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::sendCmd(char*)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:58: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::rotate(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:76: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::stopMotor()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:88: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoPos(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:103: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoAngleDeg(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:123: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoAngleRad(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:143: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoAngleDegC(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:164: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoAngleRadC(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:185: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoRel(long int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:218: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoRelDeg(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:253: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::gotoRelRad(float)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:289: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setSFGain(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:306: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setP(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:322: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setI(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:338: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setD(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:355: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setSpeed(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:372: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setI2CAddr(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:389: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'void Rhino::setPos(int)':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:406: warning: unused variable 'curr_pos'
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:415: warning: unused variable 'curr_pos'
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:426: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getPos()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:474: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'float Rhino::getAngleDeg()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:501: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'float Rhino::getAngleRad()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:528: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getSpeed()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:555: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getRotSpeed()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:582: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getI2CAddr()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:609: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getSFGain()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:636: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getP()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:663: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getI()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:690: error: 'serial' was not declared in this scope
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h: In member function 'int Rhino::getD()':
S:\Program Files (x86)\Arduino\libraries\Rhino/Rhino.h:717: error: 'serial' was not declared in this scope
