I am trying to define multiple serial ports (multiple BMS management boards) and select via a global variable the port which one is active, this is the sketch I am trying to modify.
https://github.com/bres55/Smart-BMS-arduino-Reader/blob/master/smart_bms_reader_Mega_v11.ino
The function I want to write could be called "MySerialSwitch"
The smart_bms_reader_Mega_v11.ino has 19 calls to serial in a number of different functions. I want to be able to define the "active" MySerial in a variable that can be changed on the fly.
Something like this.
#include <SoftwareSerial.h>
SoftwareSerial MySoftSerial1(10, 11); // RX, TX
SoftwareSerial MySoftSerial2(12, 13); // RX, TX
#define MySerial1 MySoftSerial1
#define MySerial2 MySoftSerial2
#define MySerial3 Serial3
char MySerialPort[] = "MySerial1";
void setup()
MySoftSerial1.begin(9600);
MySoftSerial2.begin(9600);
Serial3.begin(9600);
This function would be modified
void call_get_cells_v()
  flush(); // flush first
  uint8_t data[7] = {221, 165, 4, 0, 255, 252, 119};
  MySerial.write(data, 7);
to read.
  MySerialSwitch.write(data, 7);
I have been researching this post
How to define a SoftwareSerial object inside a class?
And this post
Writing First Library - Serial Stream Object
It’s my first attempt at creating a library, I think this is kind of what I am trying to achieve, I've done the reading on stream, references and pointers. I'm not quite clear yet. I would really appreciate some assistance.
class MySerialSwitch {
    private:
        Stream *_dev;
    public:
        MySerialSwitch(Stream *dev) : _dev(dev) {}
        MySerialSwitch(Stream &dev) : _dev(&dev) {}
        (char MySerialPort);
    (int pos) {
    _dev->write(char MySerialPort);
I found this post, I don't think it will switch between hardware serial and software serial but it certainly works for just software.
SoftwareSerial *MySerial;
void setup()
   Serial.begin(115200);
    void loop()
      MySerial = &MySoftSerial1; //Query the 1st BMS
      //or change port
      MySerial = &MySoftSerial2; //Query the 2nd BMS
      // I had to all instances of MySerial.write to MySerial->write
I'll keep reading to figure out what I've done but if anyone would like to explain, I'd be very appreciative.
This is the post I got the method from.
https://forum.arduino.cc/index.php?topic=605453.0
Thanks
