13
Okay, we all have seen those questions all over the web such as Arduino v.s. C++, or other similar questions. And a vast majority of the answers do not even touch compilation differences other than through abstracted information.
My question aims to solve the actual differences (not preferences) in how a .ino file renamed to a .cpp file or other similar file extension for c++ would compile using GCC-AVR. I know that at a minimum you have to include the Arduino header file, but beyond that, what would cause a compilation error if compiling said .ino to .cpp file using, say, for instance GCC-AVR. For simplicity's sake, lets use the classic blink example to explain what the differences are. Or if you have a better code snippet to use, please by all means, include the snippet in your answer and explain the differences thoroughly.
Please no opinions as to which is a better way or tool to use.
FYI. I use Platformio for development and I notice a conversion process happening behind the scenes during compilation. I am tryng to understand what is actually happening there, so when I code in Arduino, I understand the "pure" C++ version as well.
Thanks for your thoughtful answers to my question in advance.
Juraj
  • 18,264
  • 49
RedDogAlpha
  • 190
See my answer here: Classes and objects: how many and which file types do I actually need to use them? - specifically: How the IDE organizes things.
Yes you would need to do that.
The IDE generates function prototypes for you. Code in a .ino file may or may not need this (it probably will unless the author is disciplined enough to code in the usual C++ way and do them themselves).
If the "sketch" contains other files (eg. other .ino, .c or .cpp files) then these would need to be incorporated in the compile process as I describe in my answer mentioned above.
Also you would need to (compile and) link in any libraries used by the sketch.
You haven't asked about the linking side of things, but naturally the various files, as compiled, need to be linked together, and then turned into a .elf and .hex file for uploading purposes. See below.
Example makefile
Based on the IDE output I made a simple makefile a while back:
# Simple Arduino Makefile
# Author: Nick Gammon
# Date: 18th March 2015
# where you installed the Arduino app
ARDUINO_DIR = C:/Documents and Settings/Nick/Desktop/arduino-1.0.6/
# various programs
CC = "$(ARDUINO_DIR)hardware/tools/avr/bin/avr-gcc"
CPP = "$(ARDUINO_DIR)hardware/tools/avr/bin/avr-g++"
AR = "$(ARDUINO_DIR)hardware/tools/avr/bin/avr-ar"
OBJ_COPY = "$(ARDUINO_DIR)hardware/tools/avr/bin/avr-objcopy"
MAIN_SKETCH = Blink.cpp
# compile flags for g++ and gcc
# may need to change these
F_CPU = 16000000
MCU = atmega328p
# compile flags
GENERAL_FLAGS = -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=$(MCU) -DF_CPU=$(F_CPU)L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106
CPP_FLAGS = $(GENERAL_FLAGS) -fno-exceptions
CC_FLAGS  = $(GENERAL_FLAGS)
# location of include files
INCLUDE_FILES = "-I$(ARDUINO_DIR)hardware/arduino/cores/arduino" "-I$(ARDUINO_DIR)hardware/arduino/variants/standard"
# library sources
LIBRARY_DIR = "$(ARDUINO_DIR)hardware/arduino/cores/arduino/"
build:
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(MAIN_SKETCH) -o $(MAIN_SKETCH).o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)avr-libc/malloc.c -o malloc.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)avr-libc/realloc.c -o realloc.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)WInterrupts.c -o WInterrupts.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)wiring.c -o wiring.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)wiring_analog.c -o wiring_analog.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)wiring_digital.c -o wiring_digital.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)wiring_pulse.c -o wiring_pulse.c.o
    $(CC) $(CC_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)wiring_shift.c -o wiring_shift.c.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)CDC.cpp -o CDC.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)HardwareSerial.cpp -o HardwareSerial.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)HID.cpp -o HID.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)IPAddress.cpp -o IPAddress.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)main.cpp -o main.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)new.cpp -o new.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)Print.cpp -o Print.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)Stream.cpp -o Stream.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)Tone.cpp -o Tone.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)USBCore.cpp -o USBCore.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)WMath.cpp -o WMath.cpp.o
    $(CPP) $(CPP_FLAGS) $(INCLUDE_FILES) $(LIBRARY_DIR)WString.cpp -o WString.cpp.o
    rm core.a
    $(AR) rcs core.a malloc.c.o
    $(AR) rcs core.a realloc.c.o
    $(AR) rcs core.a WInterrupts.c.o
    $(AR) rcs core.a wiring.c.o
    $(AR) rcs core.a wiring_analog.c.o
    $(AR) rcs core.a wiring_digital.c.o
    $(AR) rcs core.a wiring_pulse.c.o
    $(AR) rcs core.a wiring_shift.c.o
    $(AR) rcs core.a CDC.cpp.o
    $(AR) rcs core.a HardwareSerial.cpp.o
    $(AR) rcs core.a HID.cpp.o
    $(AR) rcs core.a IPAddress.cpp.o
    $(AR) rcs core.a main.cpp.o
    $(AR) rcs core.a new.cpp.o
    $(AR) rcs core.a Print.cpp.o
    $(AR) rcs core.a Stream.cpp.o
    $(AR) rcs core.a Tone.cpp.o
    $(AR) rcs core.a USBCore.cpp.o
    $(AR) rcs core.a WMath.cpp.o
    $(AR) rcs core.a WString.cpp.o
    $(CC) -Os -Wl,--gc-sections -mmcu=$(MCU) -o $(MAIN_SKETCH).elf $(MAIN_SKETCH).o core.a -lm
    $(OBJ_COPY) -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 $(MAIN_SKETCH).elf $(MAIN_SKETCH).eep
    $(OBJ_COPY) -O ihex -R .eeprom $(MAIN_SKETCH).elf $(MAIN_SKETCH).hex
In that particular case, the .ino file compiled without any problems after renaming it to Blink.cpp and adding this line:
#include <Arduino.h>
Nick Gammon
  • 38,901
I would just like to add a few points to Nick Gammon's answer:
  • You do not need to rename a .ino file in order to compile it: if you explicitly tell the compiler it's C++ (option -x c++), it will ignore the unusual file extension and compile it as C++.
  • You do not need to add #include <Arduino.h> in the .ino file: you can tell the compiler to do that for you (-include Arduino.h).
Using those tricks, I can compile Blink.ino with no modification, just by invoking avr-g++ with the proper command-line options:
avr-g++ -mmcu=atmega328p -DARDUINO=105 -DF_CPU=16000000L \
    -I/usr/share/arduino/hardware/arduino/cores/arduino \
    -I/usr/share/arduino/hardware/arduino/variants/standard \
    -Os -fno-exceptions -ffunction-sections -fdata-sections \
    -Wl,--gc-sections -g -Wall -Wextra \
    -x c++ -include Arduino.h \
    /usr/share/arduino/examples/01.Basics/Blink/Blink.ino \
    -x none /usr/local/lib/arduino/uno/libcore.a -lm \
    -o Blink.elf
A few notes on the above command-line:
  • /usr/local/lib/arduino/uno/libcore.a is where I saved the compiled Arduino core. I hate recompiling over and over again the same stuff.
  • -x none is needed to tell the compiler to mind the file extensions again. Without it, it would assume libcore.a is a C++ file.
I learned those tricks from Sudar Muthu's Arduino-Makefile. This is a very general Makefile that works with many boards and with libraries. The only thing missing relative to the Arduino IDE is the forward declarations.
Edgar Bonet
  • 45,094
  • 81
