I need to convert Arduino code to avr-gcc code. This is code:
#include <Servo.h>
Servo myservo;
  myservo.attach(11);
  myservo.write(67);
I use Arduino Mega.
dda
  • 1,595
user29971
Try this:
#include <Servo.h>
extern "C" void init(void);
Servo myservo;
int main()
    init();
    myservo.attach(11);
    for (;;) {
        myservo.write(67);
Note that this still needs the Arduino core library, as the Servo library depends on it, which means all this is an exercise in futility. If you are using the Arduino core, the simplest thing is to use it the Arduino way. If you do not want to use Arduino core, then you will have to partially re-implement the Servo library.
Edgar Bonet
  • 45,094
  • 81
