In software serial, the write function only sends 1 byte at a time. Is there someway, some library, that i can send multiple bits/bytes, without stopping (and not using digitalWrite)? i want to be able to transmit at least 16 bits as opposed to just 8.
I know i can send 2 bytes, or even 100 bytes. But the thing i'm trying to do is, implement my own LDPC(error correction) codes on the Arduino. Therefore, i'm taking a lot of channel measurements. One of them is figuring out how the error happens during the delay between the stop bit and the next startbit. Often times, this is were synchronization problems occur. So I'm trying to track this down. Hence why, I need to send more than 8 continuous bits. In software serial, it transmits 8 bits, then transmits the stop bit. then write() restarts on the next call. Instead of this, i just want to send more bits, like 64 bits for instance, and look at the BLER on the received data. (the reason why I'm staying away from hardware serial is because i'm doing this with wireless RF modules) Do you guys have any further info regarding this? I'm very grateful! Thank you so much!
Also, it was suggested that I write my own softwareserial, but that's a pretty daunting task. I would like to avoid it, if i can.
EDIT: Let me show you my data. So, I'm constantly transmitting the values; 123,124,125,126.
1111011
1111100
1111101
1111110
The above 4 lines repeat about 2 times. Then, suddenly, it synchronizes incorrectly, and the following 4 lines are being constantly repeated.
11110101
11111001
11101101
11110001
It never syncs back to the original 4 transmissions. Now, inside the unsynced block of 4 transmitted bytes, there are fragments of the correct transmission inside. For instance, start from the 2nd bit of the 3rd byte of the correct transmitted byte. Now, if you account for the '0' start bit, and try to matchup the bits, the correct bits are being picked up in the correct order. It's just a problem of what the receiver takes as the startbit.
As i'm typing this edit, i realized something else. What i said in the above paragraph is true, then for the unsynced block, there should be a '0' start bit in front. Now, if the messages match up exactly, and if the 0 start bit that is being transmitted is being treated as a payload, then which 0 is being treated as the startbit, because all the bits between the synced and unsynced data are matched up. However, there should be one missing 0 each time because it's being read as a startbit, not databit.
Sorry if this is convoluted. Happy to clarify any part of it. Thank you so much!!
