ardprintf is a function that I hacked together which simulates printf over the serial connection. This function (given at the bottom) can be pasted in the beginning of the files where the function is needed. It should not create any conflicts.
It can be called similar to printf. See it in action in this example:
void setup()
Serial.begin(9600);
void loop()
int l=2;
char *j = "test";
long k = 123456789;
char s = 'g';
float f = 2.3;
ardprintf("test %d %l %c %s %f", l, k, s, j, f);
delay(5000);
The output as expected is:
test 2 123456789 g test 2.30
The function prototype is:
int ardprintf(char *, ...);
It returns the number of arguments detected in the function call.
This is the function definition:
#ifndef ARDPRINTF
#define ARDPRINTF
#define ARDBUFFER 16
#include <stdarg.h>
#include <Arduino.h>
int ardprintf(char *str, ...)
int i, count=0, j=0, flag=0;
char temp[ARDBUFFER+1];
for(i=0; str[i]!='\0';i++) if(str[i]=='%') count++;
va_list argv;
va_start(argv, count);
for(i=0,j=0; str[i]!='\0';i++)
if(str[i]=='%')
temp[j] = '\0';
Serial.print(temp);
j=0;
temp[0] = '\0';
switch(str[++i])
case 'd': Serial.print(va_arg(argv, int));
break;
case 'l': Serial.print(va_arg(argv, long));
break;
case 'f': Serial.print(va_arg(argv, double));
break;
case 'c': Serial.print((char)va_arg(argv, int));
break;
case 's': Serial.print(va_arg(argv, char *));
break;
default: ;
else
temp[j] = str[i];
j = (j+1)%ARDBUFFER;
if(j==0)
temp[ARDBUFFER] = '\0';
Serial.print(temp);
temp[0]='\0';
Serial.println();
return count + 1;
#undef ARDBUFFER
#endif
**To print the % character, use %%.*
Now, available on Github gists.
