I am trying to read digits (number from 0 to 255) from Serial port, convert them to HEX String and send them using SoftwareSerial as HEX.
For example: when I send '60' trough the serial port, the SoftwareSerial will send '3C'
currently I am using the following code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 4); // RX, TX
String inputString     = "";
boolean stringComplete = false;
int HexInt = 0;
String HexString = "00";
  Serial.begin(115200);
  mySerial.begin(38400);
  inputString.reserve(200);
  delay(500);
  Serial.println("");
  mySerial.println("");
  serialEvent();
  if(stringComplete) {
    HexInt = inputString.toInt();
    HexString = String(HexInt,HEX);
    if (HexInt<16) HexString = "0" + HexString ;
    HexString.toUpperCase();
    mySerial.println(HexString);
    Serial.println(inputString); //debug
    inputString = "";
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    if (inChar == '\n') continue;
    if (inChar == '\r') {
      stringComplete = true;
      if (inputString == "") inputString = "NULL";
      inputString.toUpperCase();
      continue;
    inputString += inChar;
My question is: Is there a more elegant / effective way to perform the same outcome?
user28282
  • 55
You have the number. It's made up of two nibbles, each representing 4 bits (1 hex character).
If you want to do a manual conversion take the first nibble (AND with 240) add it's value to "0" then do the same for the lower nibble (AND with 15).
OR
What I would do is use:
char HexString[3];
sprintf(HexString,"%02X",HexInt);
since you're not dealing with floats, you're good to go.
OR
edit: I recalled a printf function that we put together once before, I don't know if it would work with SoftwareSerial, so you might have to play around with it a bit, but as a 3rd option, you could try the following. I don't have access to an Arduino or compiler at the moment, otherwise I'd have a play with this right now.
Before your setup:
// Function that printf and related will use to print
int serial_putchar(char c, FILE* f) {
    if (c == '\n') serial_putchar('\r', f);
    return Serial.write(c) == 1? 0 : 1;
FILE serial_stdout;
In your setup, add:
// Set up stdout
fdev_setup_stream(&serial_stdout, serial_putchar, NULL, _FDEV_SETUP_WRITE);
stdout = &serial_stdout;
in your loop, change your assignment to:
HexString = printf("%02X",HexInt);
Madivad
  • 1,372
  • 26
