so I am having trouble sending data using software serial's write function.
TX Code:
#include <SoftwareSerial.h>
SoftwareSerial TX(2,3);
TX.begin(1200);
TX.write(60);
Is the delay necessary?
RX Code:
SoftwareSerial RX(2,3); //(rx pin, tx pin)
const unsigned int bufferSize = 100;
Serial.begin(9600);
RX.begin(1200);
void printBuffer(const uint8_t *serialBuffer)
//print contents of buffer
for (int i = 0; i<100; i++)
Serial.println(serialBuffer[i], BIN);
void processBytes(const uint8_t value)
static uint8_t serialBuffer[bufferSize]; //buffer to hold values
static unsigned int startPosition=0;
if(startPosition < bufferSize)
serialBuffer[startPosition++] = value;
else
printBuffer(serialBuffer);
startPosition = 0;
}//end of processBytes
//check if data is available in serial buffer
while(RX.available())
//process data
processBytes(RX.read());
If i transmit the number 60, it prints 226 constantly for 2-3 seconds, then prints 60 for a short while, then goes back to printing 226. Am I doing something wrong with my code?
FIRST QUESTION: In the case when startPosition (in the process function) equals 100, it will call print. Print will then print 100 integers. Now, when doing that, there could still be data being transmitted from the transmitter. But the read function won't be executed until printBuffer returns, process returns, and the while loop iterates again. So during that time, couldn't some transmitted values potentially not be read?
SECOND QUESTION How come Software serial doesn't synchronize incorrectly more often? How is it being so accurate if the start bit is just a single bit and it's a 0. So for instance, if payload has some 0s, how come one of those 0s aren't being assumed to be the startbit? How does this get resolved? I looked at the software serial library, but I am not able to find out why. Any guidance here?
THIRD QUESTION Other than getting the startbit syncing right, are there other ways to sync the data? I was reading of NRZ encoding, manchester encoding, etc. Can any of these be implemented here? Also, would it be wise to alter the softwareSerial library to have more than one startbit?
Any guidance would be very appreciated! Thank you so much! This is all being done with wireless RF modules.
