I have a rotary encoder KY-040 connected to a Digispark like this:
CLK go to p0 and and DT go to p2, SW is disconnected for now (it's just a button).
I did everything like the instructions here: http://henrysbench.capnfatz.com/henrys-bench/keyes-ky-040-arduino-rotary-encoder-user-manual/
#include <DigiKeyboard.h>
 int pinA = 0;  // Connected to CLK on KY-040
 int pinB = 2;  // Connected to DT on KY-040
 int encoderPosCount = 0;
 int pinALast;
 int aVal;
 boolean bCW;
   pinMode (pinA,INPUT);
   pinMode (pinB,INPUT);
   /* Read Pin A
   Whatever state it's in will reflect the last position
   pinALast = digitalRead(pinA);
   Serial.begin (9600);
   aVal = digitalRead(pinA);
   if (aVal != pinALast){ // Means the knob is rotating
     // if the knob is rotating, we need to determine direction
     // We do that by reading pin B.
     if (digitalRead(pinB) != aVal) {  // Means pin A Changed first - We're Rotating Clockwise
       encoderPosCount ++;
       bCW = true;
     } else {// Otherwise B changed first and we're moving CCW
       bCW = false;
       encoderPosCount--;
     Serial.println("Rotated: ");
     if (bCW){
       //Serial.println ("clockwise");
       DigiKeyboard.sendKeyStroke(KEY_V); //or DigiKeyboard.write("1");
     }else{
       //Serial.println("counterclockwise");
        DigiKeyboard.println("cc");
     Serial.print("Encoder Position: ");
     Serial.println(encoderPosCount);
   pinALast = aVal;
I only changed the pin numbers in the code and the Serial.println (... to any of the following:
DigiKeyboard.println("1");
All of them didn't do anything when rotating the knob...
Any ideas? Maybe the 10K resistors are too much?
shinzou
  • 155
Shown below is a KY-040 test program that in my tests doesn't lose any counts and is more accurate than some other software; it picks up the counts between detents as well as those at detents. You may be able to adapt it to your DigiKeyboard ATtiny system.
/*  roto_jw4.ino -- JW, 29 September 2015 --
 *  A 4-state state-machine implementation of rotary
 *  encoding for KY-040 rotary knobs.  The state-machine picture at
 *  https://e2e.ti.com/support/microcontrollers/hercules/f/312/t/318762
 *  in a Feb 4, 2014 7:40 PM post by Anthony Seely shows counts
 *  increasing on transitions 10 -> 11 -> 01 -> 00 -> 10 and
 *  decreasing on transitions the other way.  Transitions between 00
 *  and 11 or 10 and 01 are invalid.  This code detects valid
 *  transitions by (abOld xor abNew) equaling 1 or 2.  It detects
 *  up-count events by the tri-bit value ABA' (where A' is the new
 *  reading on pin A) being equal to 1, 2, 5, or 6 (a bit mask of
 *  0x66), and down-count events by ABA' being equal to 0, 3, 4, or 7
 *  (a bit mask of 0x99).
 *  On a KY-040 unit I tested, there are 30 detent positions per turn.
 *  With this unit the code generates 60 counts per turn, which can be
 *  seen individually as one turns the rotor slowly.  Odd counts
 *  appear between detents, even counts at detents.
 *  Set quadrature-signal pin numbers, via PinA and PinB constants.
 *  Set IPINMODE to INPUT_PULLUP if there are no external pull-ups
 *  on encoder AB pins, else set IPINMODE to INPUT
enum { PinA=2, PinB=3, IPINMODE=INPUT };
static  byte abOld;     // Initialize state
volatile int count;     // current rotary count
         int old_count;     // old rotary count
  pinMode(PinA, IPINMODE);
  pinMode(PinB, IPINMODE);
  attachInterrupt(0, pinChangeISR, CHANGE); // Set up pin-change interrupts
  attachInterrupt(1, pinChangeISR, CHANGE);
  abOld = count = old_count = 0;
  Serial.begin(115200);
  Serial.println("Starting Rotary Encoder Test");
// On interrupt, read input pins, compute new state, and adjust count
void pinChangeISR() {
  enum { upMask = 0x66, downMask = 0x99 };
  byte abNew = (digitalRead(PinA) << 1) | digitalRead(PinB);
  byte criterion = abNew^abOld;
  if (criterion==1 || criterion==2) {
    if (upMask & (1 << (2*abOld + abNew/2)))
      count++;
    else count--;       // upMask = ~downMask
  abOld = abNew;        // Save new state
  if (old_count != count) {
    Serial.print(millis());
    Serial.print("  ");
    Serial.println(count);
    old_count = count;
Since some ATtiny's only have one external-interrupt pin, it may be necessary to use two pin-change interrupts instead of two external-interrupt pins. (Six of the pins on an ATtiny45, for example, support pin-change interrupts, and only one is an external-interrupt pin.) Change PinA and PinB to appropriate pin numbers, and replace
with
  enableInterrupt(PinA, pinChangeISR, CHANGE); // Set up pin-change interrupts
  enableInterrupt(PinB, pinChangeISR, CHANGE);
and add the following #include near the beginning:
#include <EnableInterrupt.h>
To install the .h file for use via the Arduino IDE, unpack an EnableInterrupt zip file (for example, enableinterrupt-0.8.2.zip from bintray.com/greygnome) in the directory ~/sketchbook/libraries. I think the package works with ATtiny's as well as more-standard Arduinos.
James Waldby - jwpat7
  • 8,920
  • 33
Hardware Serial uses pins 0 and 1. I would try other pins. (Oh, it's an ATtiny - well I'm not sure about HardwareSerial on that, but it looks suspicious).
See my page about rotary encoders for more ideas.
Maybe post the code you actually used, that would be helpful. Not some code you didn't use.
No, that looks fine.
Nick Gammon
  • 38,901
