I want to "connect" two Arduinos, without using wires. The range is ~0.2 miles (300 meters). Using Google, I saw too many options.
The idea is to build something like a beacon, so the bandwidth can be small. I want to send 32 or 64 bits/second of data (32 bits for the application + 32 bits for checksum if the module does not guarantee consistency of data). The communication between Arduinos is bi-directional, and I'm looking for something cheaper than 50 US dollars per module.
Can I use a serial WiFi module for this, without using a router? Do you recommend a 2.4GHz module? Or a RF module?
Nick Gammon
  • 38,901
Imaky
  • 131
I can highly recommend these cheap little 433Mhz radios. You can get them on amazon, ebay, etc. and they work pretty well for me. Your distances are a bit longer than my situation but I have to go through several walls.
ThatAintWorking
  • 240
It's a bit unorthodox solution, but have you considered toy walkie-talkies? They cover the distance you reported, even if some obstacles are in the path and they are relatively cheap, if you go for some sales. It requires a bit of hacking to connect the arduino to the mic/speaker and the push button, but it shouldn't be too difficult.
Igor Stoppa
  • 2,125
