So I've tried this a few times and I always get the same issue. When I try to run the sweep example the servo goes round 180 degrees but only in steps. Anyone know a way to fix this?
The servo I'm using is a Tower Pro Micro Servo 9G SG90
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
void setup()
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop()
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
Video: http://vidd.me/A40
sachleen
  • 7,565
  • 40
  • 57
Jordan Adams
  • 169
6 Answers6
In electronics, as usual in situations where a cricuit is misbehaving and we don't understand why, a solution that generally works is to add a decoupling cap between +5V and GND.
In your case, I would put at least 220uF; that would ensure two things:
  • the voltage used to control the servo never drops
  • the voltage brought to Arduino by the USB does not drop either (which would have very bad impact on the Arduino, probably resetting it)
Electrolytic caps are a must-have for every electronics hobbyist (and professional as well, of course).
You can read more about decoupling capacitors on Wikipedia.
Edit:
According to @gwideman comment, it seems that using a decoupling capacitance above 10uF in a USB 2.0 device would violate USB specs and may damage the USB host controller on the computer.
I was not aware of this limitation but I have already used decoupling capacitance up to 100uF in my circuits and never got any issue with my USB computer port.
It might be due to extra electronics on the Arduino board that would "isolate" USB power from Arduino +5V anf d GND pins, I don't know (that should probably be the topic of a specific question); or maybe I have just been lucky all this time...
jfpoilpret
  • 9,162
  • 38
  • 54
I've experienced same behavior with this type of servos. In my case it was easier to spot since Arduino frequently rebooted when servo was approaching the boundaries of the swing - so it was clear it was consuming too much power, and USB port was unable to deliver that.
Cheap dedicated 9V 1A AC/DC converter usually solves the problem. But if you can't wait for one to get delivered, get an iPad USB charger (nowadays everyone has it or has a neighbor/friend who has one). It is rated 10W, and it doesn't suffer from voltage drops even under high loads. Power your setup from it, and if you'd see it moves smoothly, you will have your answer.
Alexander
  • 101
It looks like your sketch runs in slow motion.
Check if you wrote delay(150) or have an additional delay in your loop. Check twice and - just to make sure - upload the corrected sketch again.
Edit: If possible, test with another servo and even test with another Arduino board.
suit4
give a 9v supply +ve terminal to Vin and -ve ground. since the arduino board cannot supply enough power to the servo, this will provide this worked for me and workin just fine
Akash
I tested your code, nothing wrong with it. Maybe it is power supply issue. 1. Don't use USB to power servo, it can make current spike when it move rapidly. 2. Use proper supply for servo. High current and use large capacitor to deal with current spike.
The program is faulty. 1) No servo can react to a command in 15 milliseconds. Delay should be more like 500 milliseconds (.5 seconds). 2) The for loops are not designed to work together. The 1st loop feeds a value of 181to the second loop which is designed to start with a value of 180. The 2nd loop feeds a value of -1 back to the first loop, which is designed to start with a value of 0.
