I am using an encoder motor for one of my projects and i was reading encoder values manually through Arduino. It was working fine when i turned it slowly, but whenever i would rotate it at some higher speed, data input to the arduino would stop. I am using the encoder at 4 x.
Can somebody help me with some code to read the data from encoder faster.
    int pulses, A_SIG=0, B_SIG=1;
void setup(){
  attachInterrupt(0, A_RISE, RISING);
  attachInterrupt(1, B_RISE, RISING);
  Serial.begin(115200);
}//setup
void loop(){
void A_RISE(){
 detachInterrupt(0);
 A_SIG=1;
 if(B_SIG==0)
  pulses++;//moving forward
 if(B_SIG==1)
  pulses--;//moving reverse
 Serial.println(pulses);
 attachInterrupt(0, A_FALL, FALLING);
void A_FALL(){
  detachInterrupt(0);
 A_SIG=0;
 if(B_SIG==1)
 if(B_SIG==0)
void B_RISE(){
  detachInterrupt(1);
  B_SIG=1;
  if(A_SIG==1)
  if(A_SIG==0)
  attachInterrupt(1, B_FALL, FALLING);
 void B_FALL(){
    detachInterrupt(1);
    B_SIG=0;
    if(A_SIG==0)
    if(A_SIG==1)
Adnan
volatile long rawTacho[2];      // interrupt 0 & 1 tachometers
ISR(MotorISR1)
    int b = digitalReadFast(8);
    if (digitalReadFast(2))
        b ? rawTacho[0]-- : rawTacho[0]++;
    else
        b ? rawTacho[0]++ : rawTacho[0]--;
ISR(MotorISR2)
    int b = digitalReadFast(9);
    if (digitalReadFast(3))
        b ? rawTacho[1]-- : rawTacho[1]++;
    else
       b ? rawTacho[1]++ : rawTacho[1]--;
void setup()
    pinMode(2, INPUT_PULLUP);
    pinMode(3, INPUT_PULLUP);
    pinMode(8, INPUT_PULLUP);
    pinMode(9, INPUT_PULLUP);
   attachInterrupt(PCINT0, MotorISR1, CHANGE);  // pin 2
   attachInterrupt(PCINT1, MotorISR2, CHANGE); // pin 3
something similar to that - it was extracted from bigger code so you will have read it and understand it as opposed to copy paste.
Update note: This is not complete in a pure form - the cpu doesnt tell you what pin had an interrupt - thus some underlying Arduino code figures that out for me, but it is fairly efficient, and I used it as is. Also if it is not obvious, this is reading encoders from 2 motors. 1 interrupt is assigned to each motor, the second phase of each is on a non-interrupt pin. Never lost a reading to my knowledge.
The problem with your code is probably the print in the interrupt as pointed out in a comment.
I built a measuring bench using a glass slide (intended for DRO) with quadrature output. I found the Arduino was easily overwhelmed and would miss beats. I also tried implementing a D flip flop to halve the resolution of the slide. Ultimately, I put a LS7166 IC in the prototyping area of the freeduino eleven I was using and then performed a PORT read on D0-D7.
Krista K
  • 526
