I have a USB to Serial TTL PL2303HX (Prolific chipset) that I would like to connect to my Pi. My Pi model is 2011.12.
The USB to Serial adapter has 5 PINs labeled as follows:
  • 3V3
  • TXD
  • RXD
  • GND
  • +5V
I received 4 cables with the USB to Serial Adapter (4 female-female dupont connectors).
I've seen various diagrams of the GPIO, but I'm not sure which PINS on the GPIO go to the PINs on the adapter.
Question: Which PINs on the GPIO need to be wired to which PINs on the USB adapter?
Chris Snow
  • 263
You only need to connect GND, RXD, TXD
GND => PIN 6
RXD => PIN 8
TXD => PIN 10
John La Rooy
  • 12,005
  • 48
  • 77
In addition to John La Rooy's answer, I've also connected VCC (i.e., +5V) to PIN 2. Thus, my Pi receives enough power from my computer to boot from a USB key.
user1448926
  • 121
I can tell you the WRONG way. I did as above but also connected the 3v3 pin on the prolific dongle to the 3v3 pin on the pi and apparently it fried the pi. Not sure why. I wish someone would give an explanation.
Jimbob
