Hi guys I want to create a basic GUI with TKinter.
This is my code
from tkinter import*
import tkinter.font
win =Tk()
win.title("Test")
myFont = tkinter.font.Font( family = 'Helvetica', size = 12, weight = 'bold')
def ledToggle():
        print("Hello World")
button1 = Button(win,text ='Test', font = myFont,command = ledToggle, bg='bisque2$
button1.grid(row=0,column=1)
I get this error message:
  File "gui.py", line 4, in <module>
    win =Tk()
  File "/usr/lib/python3.5/tkinter/__init__.py", line 1880, in __init__
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: no display name and no $DISPLAY environment variable
Shalomi90
  • 121
this error usually happens when you access the RPI via SSH, you could run:
export DISPLAY=0:0
or add it to your bashrc if you want it to be perminantly excuted on every therminal run and ssh connection.
EDIT (a great suggestion by roger-jones):
you can also set the variable by prefixing it to the command: DISPLAY=0:0 python gui.py.
If you SSH with PuTTY you can also add the DISPLAY to the environment at "Connection">"Data">"Environment Variables"
if your not satisfied, check out similar errors as yours: link
aa-samad
  • 166
I've come up with a solution!
import Tkinter
import sys
import os
# check if
if os.environ.get('DISPLAY','') == '':
    print('no display found. Using :0.0')
    os.environ.__setitem__('DISPLAY', ':0.0')
master = Tkinter.Tk()
#master.title("tester")
#master.geometry("300x100")
# Lay out label
#label.pack()
# Run forever!
master.mainloop()
Brian Lee
