I have a headless build; which has no x11 server nor any desktop manager.
I would like to run some music applications; so I can use a small touch screen that I recently found; and I was wondering if there is a way to run an application from terminal, that launch a UI, without install the ton of packages required to run a X11 server.
My whole system run on 2 GB; I would like to use this configuration (board plus touchscreen) as controller for a midi keyboard; so I can have a stand alone synthesizer basically; and use the touchscreen to change banks, samples, midi instruments or parameters.
Not sure if this is even possible; I always ran applications via X11 on linux, but I thought that asking here may give me some ideas.
The final objective is to have the board to run connected to a midi keyboard as standalone; if I need to flash again the sd card that's fine; I can use a larger one, if there is a distribution that works for my case; otherwise I don't mind to geek out on the file system and make changes to make it happen; although I am not able to find much on the subject.
rataplan
  • 196
You don't need X11 or a desktop environment to have a user interface (UI). X11 is just one (widely used) option if you want a graphical user interface. The desktop environments for Linux usually build on X11, and provide many other functions, a window manager is just one of those.
If you have just one application in mind, a desktop environment is certainly overkill.
If you write your application yourself, you can just address the screen yourself. But it may be easier to just install the X Server without many of the fancy libraries, and just pass the commands to draw on the screen to the X Server, because that is the purpose of the X Server.
However, if you don't write your application yourself, you must install whatever the application needs. But there are also applications like aplay that can play a sound and don't need X11.
Regarding the size, 2GB should be enough for an X11 installation.
RalfFriedl
  • 2,180
I run a minimal X11 desktop using the icewm window manager and xdm for display manager on Raspbian. Starting with Stretch Lite, I install the following packages:
apt-get install xserver-xorg xserver-xorg-core xserver-common xdm icewm xterm x11-apps \
        xfonts-base xfonts-100dpi xfonts-75dpi xfonts-scalable
Not sure how much space these require, but it's definitely a LOT less than any full-blown desktop environment. If you also want to use VNC with this, you can install tigervnc-standalone-server and use the configuration details described in How To Install and Configure efficient LAN-based VNC on raspbian
bls
  • 520
