Here's the code, it communicates with Sonic Pi, don't know if that matters:
import RPi.GPIO as GPIO
import time
import signal
import sys
from pythonosc import udp_client
from pythonosc import osc_message_builder
#from scipy.interpolate import interpld
# use Raspberry Pi board pin numbers
GPIO.setmode(GPIO.BCM)
# set GPIO Pins
pinTrigger = 18
pinEcho = 24
sender = udp_client.SimpleUDPClient('127.0.0.1', 4559)
def close(signal, frame):
print("\nTurning off ultrasonic distance detection...\n")
GPIO.cleanup()
sys.exit(0)
lastpitch1=60
lastpitch2=64
lastpitch3=67
lastpitch4=72
lastpitch5=69
pitch1 =60
pitch2 =64
pitch3 =67
pitch4 =72
pitch5 =69
signal.signal(signal.SIGINT, close)
# set GPIO input and output channels
GPIO.setup(pinTrigger, GPIO.OUT)
GPIO.setup(pinEcho, GPIO.IN)
while True:
# set Trigger to HIGH
GPIO.output(pinTrigger, True)
# set Trigger after 0.01ms to LOW
time.sleep(0.00001)
GPIO.output(pinTrigger, False)
startTime = time.time()
stopTime = time.time()
abortTime = time.time() + 0.5
while 0 == GPIO.input(pinEcho):
if startTime > abortTime:
exit
while 1 == GPIO.input(pinEcho):
if stopTime > abortTime:
exit
# time difference between start and arrival
TimeElapsed = stopTime - startTime
# multiply with the sonic speed (34300 cm/s)
# and divide by 2, because there and back
distance = (TimeElapsed * 34300) / 2
print ("Distance: %.1f cm" % distance)
if distance < 10:
pitch1=lastpitch1
pitch2=lastpitch2
pitch3=lastpitch3
pitch4=lastpitch4
pitch5=lastpitch5
elif 10 < distance < 50:
pitch1 = 60
pitch2 = 64
pitch3 = 67
pitch4 = 72
pitch5 = 69
lastpitch1=pitch1
lastpitch2=pitch2
lastpitch3=pitch3
lastpitch4=pitch4
lastpitch5=pitch5
elif 51 < distance < 100:
pitch1 = 65
pitch2 = 69
pitch3 = 72
pitch4 = 75
pitch5 = 74
lastpitch1=pitch1
lastpitch2=pitch2
lastpitch3=pitch3
lastpitch4=pitch4
lastpitch5=pitch5
elif 101 < distance < 150:
pitch1 = 67
pitch2 = 71
pitch3 = 74
pitch4 = 65
pitch5 = 76
lastpitch1=pitch1
lastpitch2=pitch2
lastpitch3=pitch3
lastpitch4=pitch4
lastpitch5=pitch5
elif 150 < distance:
pitch1 = lastpitch1
pitch2 = lastpitch2
pitch3 = lastpitch3
pitch4 = lastpitch4
pitch5 = lastpitch5
sender.send_message('/note_a', pitch1-24)
sender.send_message('/note_b', pitch2-24)
sender.send_message('/note_c', pitch3-24)
sender.send_message('/note_d', pitch4-24)
sender.send_message('/note_e', pitch5-24)
#print ("Pitch: " + pitch1 + ", Pitch2: " + pitch2 + ", Pitch3: " + pitch3)
time.sleep(.0001)
