I have installed
  • postfix
  • dovecot
  • fail2ban
  • postgray
daemons on top of the Linux mail 4.14.98+ #1200 Tue Feb 12 20:11:02 GMT 2019 armv6l GNU/Linux
Also, I have connected rpi0 to another rpi over usb-otg (to have a serial and ethernet access).
Unfortunately, even though rpi0 has low load, when ssh to it, every typing takes seconds, and in lot cases connection break due to timeout.
  CPU[#*                        3.2%]   Tasks: 54, 17 thr; 1 running
  Mem[|||||||####*********87.6M/433M]   Load average: 0.02 0.04 0.05
  Swp[                         0K/0K]   Uptime: 23 days, 02:36:02
When I connect to rpi0 via serial link - everything works fine, no delays, no timeouts.
So, question is -- which software may cause a delay?
Andrii Zhuk
Uncommenting the following line in /etc/ssh/sshd_config did the trick for me, and my ssh session were not slow anymore afterwards:
UseDNS no
Don't forget to restart the ssh service after modifying the config file:
service ssh restart
UseDNS didn't help me. What finally did was to go into the pi's ssh_conf and sshd_conf and add
IPQoS 0x00
It is suggested that an alternative might be to add
-o IPQoS=0
to the client's ssh command line, and that it might be worth changing that value from 0 to throughput.
Basically, open-ssh tries to use the Quality of Service figure for the connection to optimize its performance... and the default assumes a reliability that the Pi Zero W, with its weak WiFi hardware, can't reliably achieve. That causes long timeouts and loss of connection. Setting IPQoS to "we know it's a bad connection" makes the protocol less efficient but lets it recover from problems much more quickly.
Hope this helps others. Now I need to look up the packet-level details of what this setting does to the SSH protocol...
keshlam
  • 211
