I just upgraded a Raspberry Pi 3 Model B from Jessie to Stretch, and everything (including WiFi) seems to be working OK, but one thing has me worried: Whenever I reboot, sudo journalctl contains the following errors:
May 28 17:41:48 RasSpy3 wpa_supplicant[445]: ctrl_iface exists and seems to be in use - cannot override it
May 28 17:41:48 RasSpy3 wpa_supplicant[445]: Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
May 28 17:41:48 RasSpy3 wpa_supplicant[445]: Failed to initialize control interface 'DIR=/var/run/wpa_supplicant GROUP=netdev'.
                                                            You may have another wpa_supplicant process already running or the file was
                                                            left by an unclean termination of wpa_supplicant in which case you will need
                                                            to manually remove this file before starting wpa_supplicant again.
I think systemd is starting wpa_supplicant and then dhcpcd-run-hooks is trying to start it again. I say this because of the output from grep -i wpa /var/log/syslog:
May 28 17:41:48 RasSpy3 systemd[1]: Starting WPA supplicant...
May 28 17:41:48 RasSpy3 wpa_supplicant[323]: Successfully initialized wpa_supplicant
May 28 17:41:48 RasSpy3 systemd[1]: Started WPA supplicant.
May 28 17:41:48 RasSpy3 dhcpcd[329]: wlan0: starting wpa_supplicant
May 28 17:41:48 RasSpy3 dhcpcd-run-hooks[389]: wlan0: starting wpa_supplicant
May 28 17:41:48 RasSpy3 wpa_supplicant[445]: Successfully initialized wpa_supplicant
May 28 17:41:48 RasSpy3 wpa_supplicant[445]: Failed to initialize control interface 'DIR=/var/run/wpa_supplicant GROUP=netdev'.#012You may have another wpa_supplicant process already running or the file was#012left by an unclean termination of wpa_supplicant in which case you will need#012to manually remove this file before starting wpa_supplicant again.
Anyone know what could be causing this behavior?
