I run a mqtt server on raspberry pi 3B together with a mqtt client on android handset. A data sequence will be transferred from the server to the client by TCP.
I enabled ip over bluetooth on raspberry pi 3B following the answer of How can I set up a bluetooth PAN connection with a Raspberry Pi and an iPod?
However, the transfer speed is much slower than wifi connection. It took about 5 seconds to transfer a length 8192 integer sequence, while wifi costs about 0.5 seconds.
This is how I implemented mqtt TCP https://stackoverflow.com/questions/56165209/mqtt-transfer-speed-much-slower-when-data-size-increases-on-tcp.
I cut off the wifi power with rfkill block wifi, and move the handset right next to raspberry pi, which improve the transfer speed a little. But it still takes about 3 seconds to transfer a length 8192 integer sequence.
I am wondering whether the setup of ip over bluetooth is not right, or something else I have missed.
Please advise, thanks in advance.
exds75
I'd be inclined to wonder why my WiFi was slow instead of Bluetooth. Just as a rough figure of merit, WiFi could be 300x faster than Bluetooth (ref).
And with respect to, 3 seconds to transfer a length 8192 integer sequence:
  • The ref indicates Bluetooth data rates can be as much as 2.1 Mbps, but also says there's a 200 msec latency. Could you be incurring multiple latencies due to the way in which you're transferring things?
  • What exactly is a is a length 8192 integer sequence... how many bits is that?
I'm afraid this is not really an answer, but more of a reminder that measurement of transfer rates, and comparison to published specifications is an endeavor that requires a fair amount of specificity. 3 seconds seems a bit long to me also, but your question may be lacking enough detail to allow anyone to offer a reasoned opinion opinion, much less a specific answer.
Seamus
  • 23,558
  • 83
