19
How to setup of Raspberry Pi 3 B+ onboard WiFi for Ubuntu Server 18.04? In particular, with netplan?
This is a clean install of the Ubuntu Server 18.04 image for Raspberry Pi 3. File: ubuntu-18.04.2-preinstalled-server-arm64+raspi3.img.xz.
The installed file /etc/network/interfaces states that netplan has replaced ifupdown.
# ifupdown has been replaced by netplan(5) on this system.  See
# /etc/netplan for current configuration.
/etc/netplan has one file 50-cloud-init.yaml
# This file is generated from information provided by
# the datasource.  Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
    version: 2
    ethernets:
        eth0:
            dhcp4: true
            match:
                macaddress: <MAC 'eth0' [IF1]>
            set-name: eth0
Netplan.io provides some general Netplan configuration examples.
To configure netplan, save configuration files under /etc/netplan/ with a .yaml extension (e.g. /etc/netplan/config.yaml), then run sudo netplan apply.
... yet, no guideance specific to a RaspberryPi. ...in particular, with respect to the existing /etc/netplan/50-cloud-init.yaml file on the RaspberryPi Ubuntu Server install.
What would be the netplan template for the RaspberryPi? Can the existing /etc/cloud/cloud.cfg.d be left enabled? What is lost if cloud.cfg.d on the Raspberry Pi is disabled? ... (... and, wondering ... how much of this issue needs RaspPi knowledge vs. Ubuntu knowledge.)
Note: Since this question is at the intersection of Ubuntu & Raspberry Pi, a related question was also posted on AskUbuntu.
marc-medley
  • 543
The steps below were found to provide a persistent WiFi setup using netplan with Ubuntu Server 18.04 ubuntu-18.04.2-preinstalled-server-arm64+raspi3.img.xz image on a Raspberry Pi 3 B+.
Update system:
sudo apt update
sudo apt full-upgrade
sudo reboot
Determine interface names:
ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> …
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> … state UP …
3: wlan0: <BROADCAST,MULTICAST> … state DOWN
Determine your-cloud-init.yaml and open for editing.
cd /etc/netplan/
ls -l
# -rw-r--r-- 1 root root 666 May 15 22:00 50-cloud-init.yaml
### note your *cloud-init.yaml file name
backup *cloud-init.yaml file
cp 50-cloud-init.yaml 50-cloud-init.yaml.bak
restrict read access
sudo chmod 640 /etc/netplan/50-cloud-init.yaml
edit *cloud-init.yaml
sudo nano 50-cloud-init.yaml
Add WiFi access information to your-cloud-init.yaml file.
network:
    version: 2
    ethernets:
        eth0:
            optional: true
            dhcp4: true
    # add wifi setup information here ...
    wifis:
        wlan0:
            optional: true
            access-points:
                "YOUR-SSID-NAME":
                    password: "YOUR-NETWORK-PASSWORD"
            dhcp4: true
Test, generate and apply the changed your-cloud-init.yaml config:
  • Testing: sudo netplan --debug try (continue even if there are errors)
  • Generate: sudo netplan --debug generate (provides more details in case of issues with the previous command)
  • Apply: sudo netplan --debug apply (if no issues during the previous commands)
Confirmation Test:
sudo reboot
wait, then without the wired ethernet connected ...
ssh ubuntu@wifi-ip-address
The above sequence was distilled from the "Raspberry Pi 3B/B+ Wireless Bridge using Ubuntu Server 18.04 ARM Image and Netplan" gist link mentioned in the question comments by Larnu. The gist goes well beyond just enabling WiFi since its turns the Pi into a Bridge.
Some additional useful WiFi setup steps.
Set hostname.
sudo hostnamectl set-hostname my-server-name
sudo nano /etc/hosts
127.0.0.1 localhost
# add host name
127.0.0.1 my-server-name
sudo nano /etc/cloud/cloud.cfg
# Set preserve_hostname to true for persistance after reboot
preserve_hostname: true
Verify from local Raspberry Pi commandline.
hostnamectl
#   Static hostname: my-server-name
#         Icon name: computer
#        Machine ID: …
#           Boot ID: …
#  Operating System: Ubuntu 18.04.2 LTS
#            Kernel: Linux 4.15.0-1036-raspi2
#      Architecture: arm64
Enable mDNS.
If desired, enable Multicast DNS by installing Avahi. Avahi supports the mDNS/DNS-SD/RFC 3927/Zeroconf/Bonjour specification.
sudo apt install avahi-daemon
Remotely check mDNS resolution from another computer.
ping my-server-name.local
ssh ubuntu@my-server-name.local
marc-medley
  • 543
