Due to an sd card corruption I decided to mount the root fs as read only. Therefore, I added the 'ro' argument in /etc/fstab
/dev/mmcblk0p1  /boot           vfat    defaults,ro          0       2
/dev/mmcblk0p2  /               ext4    defaults,ro,noatime  0       1
After the device is booted, the filesystem is mounted read-only - so that's fine. However, sometimes I need write access to the file system. So, I remount the root fs with
sudo mount / -o remount,rw
as read/write. However, if I want to remount the filesystem with
sudo mount / -o remount,ro
I get the following error:
mount: / is busy
If I run:
fuser -v ./
I get the following output:
USER PID ACCESS COMMAND
pi   2421 ..c.. sftp-server
pi   2477 ..c.. bash
Does anybody know what's causing the problem? Why can the filesystem be mounted as read only at startup, but not if I remount it manually?
RPiAwesomeness
  • 3,021
  • 52
user9760
6 Answers6
You can emulate a magic sysrq keypress by executing
# echo "u" > /proc/sysrq-trigger
This causes the kernel to low-level try to remount all filesystems read only, see here.
dpq
  • 161
This is most likely because something (by the looks of that command it is the BASH shell and SFTP-Server) is/are accessing the root filesystem. During boot nothing is accessing anything in / yet, so it can be set to read-only.
However, once boot-up is complete, some software may want a lock on the filesystem or some files are being changed within. Obviously, as all the files that Raspbian uses - software, personal files, logs, etc. - are within the root filesystem. Thus you get the mount: / is busy error.
If you were able to kill both BASH and SFTP-server and then run the command, I suspect that it would work fine. However, because BASH is the way you are entering the commands, and BASH is stored on the / partition, that can't happen.
RPiAwesomeness
  • 3,021
  • 52
If you still can not unmount or remount your device after stopping all services and processes with open files, then there may be a swap file or swap partition keeping your device busy. This will not show up with fuser or lsof. Turn off swapping with:
sudo swapoff -a
You could check beforehand and show a summary of any swap partitions or swap files with:
swapon -s
or:
cat /proc/swaps
As an alternative to using the command sudo swapoff -a, you might also be able to disable the swap by stopping a service or systemd unit. For example:
sudo systemctl stop dphys-swapfile
or:
sudo systemctl stop var-swap.swap
In my case, turning off swap was necessary, in addition to stopping any services and processes with files open for writing, so that I could remount my root partition as read only in order to run fsck on my root partition without rebooting. This was necessary on a Raspberry Pi running Raspbian Jessie.
On many SD cards, there is a switch prohibiting write access. If it is off, switch it the other way to disable write protection.
Image Courtesy of jackenhack.com
If the switch is not to blame, I would advise following the advice here for rescuing.
Qu0rk
  • 111
I was banging the same wall for a long time, until I found this: https://wiki.debian.org/ReadonlyRoot#Find_processes_blocking_the_remount_readonly
When lsof and fuser do not show any files opened for writing on / (which seems your case), there could still be processes that have opened files that were deleted since, and they are blocking the remount.
The following command shows these proceses:
lsof +L1; lsof|sed -n '/SYSV/d; /DEL\|(path /p;' |grep -Ev '/(dev|home|tmp|var)'
After restarting deamons shown in the list and killing the rest, mount -o remount,ro / went fine.
Osman-pasha
  • 418
you probably have some app writing to the filesystem... i suspect the sftp-server is transferring something.
So until the file is not write closed or killed, it's probably locking up the remount as ro
higuita
  • 684
