Could someone help me to fix this error while trying to connect RPi 3 B+ to an inverter in order to read data via CH340G usb module, Below the used code :
from pymodbus.client.sync import ModbusSerialClient as ModbusClient
from pymodbus.register_read_message import ReadInputRegistersResponse
client = ModbusClient(method='rtu', port='/dev/ttyUSB0', stopbits=1, bytesize=8, parity='N', baudrate=9600, timeout=0.3)
connection=client.connect()
print(connection)
value=client.read_input_registers(2301, 4, unit=0x01)
print(value.registers)
Error message:
Traceback (most recent call last): File "/home/iot/Desktop/test.py", line 6, in value=client.read_input_registers(2301, 8, unit=0x01)                           File "/usr/local/lib/python3.6/dist-packages/pymodbus/client/common.py", line 125, in read_input_registers – return self.execute(request)
File "/usr/local/lib/python3.6/dist-packages/pymodbus/client/sync.py", line 105, in execute raise ConnectionException("Failed to connect[%s]" % (self.str())) pymodbus.exceptions.ConnectionException: Modbus Error: [Connection] Failed to connect[ModbusSerialClient(rtu baud[9600])]
Ghanima
  • 15,958
  • 65
Brahim
Setup Rpi3B+ config = CH340 USB/TTL adapter UART connfig = /dev/ttyUSB0, 96008N1, timeout = 0.3
Error = "/usr/local/lib/python3.6/dist-packages/pymodbus/client/sync.py", line 105 failed to connect
Rpi CH340 seems not able to connect to pymodus. Suggest to first do Rpi/CH340 side loopback test.
Pymodbus A Python Modbus Stack - 2018oct23
Modbus communication RpiSE Post - 2018may02
