I tried wiring one white LED to the 3.3V pin on a Pi Zero W with a 330 Ohm resistor but it's not as bright as I would like. If I wire it up without a resister I get a good amount of brightness. Is that a viable solution? Or should I try a smaller resistor?
If it matters, the power supply is a standard 5V 2.5A supply like this one. The LED is this one.
dikuw
  • 198
You need to consider that the forward voltage of a white LED is likely in the range of 3.0 V to 3.2 V (according to the linked article). Assuming the best case of 3.0 V and a resistor of 330 Ohms and using Ohm's law R = U / I we find that the current is about 1 mA and thus the brightness of the LED is rather low. Decreasing the resistor will help to some degree but be aware that this is borderline in any case. Say 33 Ohms will get you about 10 mA which might be ok. Best bet is to use the 5 V instead and design the resistor in such a fashion that the current suits the safe operational range of the LED.
Connecting a LED to a voltage source without a current limiting resistor is not a safe way of operating a LED. It is therefore not advisable to do so.
Find a more elaborate description of the calculations here; even though it is aiming at GPIO pins the physics still apply.
Ghanima
  • 15,958
  • 65
GPIOs on the Pi can deliver 8mA maximum by default. They can be configured to deliver between 2mA and 16mA as well.
So likely when you omit the resistor you are getting around 8mA. With the resistor you are limited to about 1mA.
I can't find a datasheet for that LED but 1mA is probably a bit low. Most white LEDs need a bit more than that. But it's also a good idea not to rely on the current limiting built in to the Pi. It's designed to protect the Pi, not regulate current to the LED. A smaller resistor is a better option.
user
  • 109
