26
I would like to use my Pi as a print server. My printer is supported by the computer I want to use as a print server. Is it fast enough and has enough for this? How do I setup a print server with the recommended debian image?
Bengt
  • 2,427
  • 22
  • 26
Preamble
As pointed out by several other helpful members (Okay. @AlexChamberlain to be honest.) you need to make sure that your printer drivers work first! If you can't print regularly from your computer there is no use converting it to a printing server.
The procedure for installing the printer is beyond the scope of this answer, but at the very least, must include installing CUPS, which includes the daemon.You can do that by running the following.
$ sudo apt-get install cups
On Debian or the following on Arch Linux.
$ sudo pacman -S cups
Server
You just need to reconfigure the server to allow other machines to access your printer. You're going to be editing the /etc/cups/cupsd.conf file and there are two things you need to specify.
  1. The connection to listen to.
  2. Which machines can use the printer.
Here is one that should suit our needs, feel free to change the values.
# /etc/cups/cupsd.conf
Listen *:49631
<Location /printers>
  Order allow,deny
  Allow 192.168.0.*
  Allow 192.168.1.*
</Location>
Finally we just need to restart the CUPS daemon. Remember that anytime you change something in the config file you need to restart the daemon. On Debian, run
$ sudo /etc/init.d/cups restart
Tada! We have set up the server! =D Now we just need to set up the client...
Client
Windows
To allow Window machines to print via our CUPS server we need to provide them with an http:// address. In order to do this we are going to install samba
$ sudo aptitude install samba
Make sure you restart the CUPS daemon.
And now we can tell Windows to use the following URL! (Make sure that you edit it to reflect your specific setup.)
http://<ip>:<port>/printers/<printer_name>
Arch Linux
Since installing printers differs window manager to window manager we are going to do this the old-fashion, true-Arch way! First you need to install libcups.
$ sudo pacman -S libcups
And then you just add the CUPS server IP or hostname to /etc/cups/client.conf. Your file should look like this.
# /etc/cups/client.conf
ServerName hostname-or-ip-address[:port]
Every application should then be able to find the printer.
  1. Printer Sharing - SystemPrinting - Debian Wiki
  2. CUPS as Print Server for Window Machines - SystemPrinting - Debian Wiki
  3. Installing the client package - CUPS - ArchWiki
