45
At present all of the official builds of the X Window System run on the CPU, which takes up a lot of processing power and runs X rather slowly.
I know there's no official GPU accelerated version of X11 yet, at least not from X.org, but has anyone worked on this and released anything behind the scenes?
Jivings
  • 22,656
  • 94
  • 140
berry120
  • 10,984
  • 53
  • 63
6 Answers6
17
According to the official Raspberry_Pi twitter feed, GPU accelerated X.org is not yet available.
26 June 2012: @Raspberry_Pi :
The Wheezy beta's worth a go http://www.raspberrypi.org/archives/1435 - but X isn't hardware accelerated yet. (It will be soon.)
KnipSter
  • 336
Currently, best two answers are from Raspberry PI's Liz and forum poster Simon (teh_orph):
  • "Accelerated X will be a solved problem soon; we've put engineering resource on it, and it's actively being worked on."
http://www.raspberrypi.org/phpBB3/viewtopic.php?p=194400#p194400
  • "I've finally gotten a handle on the AXI burst value (...) That's a 5x increase in window dragging/upload/download performance..."
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=4649&start=200#p197360
So, in both cases, the answer is NO, but things may change soon :-)
Henrique
  • 61
Eric Anholt has been working on completely overhauling the Raspberry Graphics Stack since July 2014. This means it was done "properly" - everything is opensource and directly in upstream: kernel.org, mesa3d.org, x.org etc. This also means everything using OpenGL inside X (GLX) automatically started working as soon his efforts flowed down into Raspbian !
As of 2018, his work is already included in Raspbian but disabled by default. Some stability issues remain. Start raspi-config and go to "Advanced options".
You can follow Erics trials and tribulations on his blog "This week in VC4 " ("VideoCore 4" is the name of the Raspberry Pi GPU)
flakeshake
  • 6,244
  • 35
There is (kind of). A nice bit of work has been done with Wayland/Weston support for RPi. It's not X11 server anymore, but there's emulation interface for X11 applications, which gives faster updates than the native, unaccelerated X.Org. The new versions of GTK & QT support it.
See (you get 500Mpix/sec from the VideoCore):
1) http://www.raspberrypi.org/archives/4053
2)http://www.collabora.com/services/case-studies/raspberrypi/
A.Genchev
There is an experimental release of an accelerated X server available here:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=28294
Sources are available over at github:
https://github.com/simonjhall/fbdev_exa
The whole thing is supposed to be still somewhat buggy, and there are warnings about possible data loss etc. But still I think it would be good if some people would test drive it.
Arne
  • 2,234
  • 35
The unofficial (is there any official?) Xorg driver details can be found here: http://elinux.org/RPi_Xorg_rpi_Driver
Tihauan
  • 109
