-2
Every time I install 2018-11-13-raspbian-stretch-full.img or 2018-11-13-raspbian-stretch-lite.img on my SD card and plug it in the Raspberry Pi 3 B+ device, they first time it runs fine but I am presented with the error kernelPanic: VFS: can't mount root fs (179,2) after I restart the device.
By default the value is something like root=PARTITION=<someting> in the cmdline.txt file. I tried setting to root=/dev/mmcblk0p6 as it is suggested in different resources, it didn't help me either. I even tried root=/dev/sda2 and root=/dev/mmcblk0p2 but all in vain. I am sure that I eject the SD card safely after making the changes.
I am installing the images using Windows 10, SD Card Formatter for formatting the SD Card, Balena Etcher to Flash the images.
What else can be tried to fix the problem?
The cause of the issue is simply that Linux cannot find the root partition.
If you view your current cmdline.txt and config.txt you will find something like root=PARTUUID=c1dc39e5-02 which is meant to match the partition UUID (the universally unique identifier).
I would suggest finding what the partition is and using that mountpoint specifically. If I remember correctly it is root=/dev/mmcblk0p7 - 7, rather than 6. This is set to the partition layout of whatever Raspbian does; it could change for future versions.
You can use the partition manager in Windows to observe what partitions are there; the biggest one should be the root partition. Just count its number from the left.
Fred
  • 4,592
  • 29
You wrote:
By default the value is something like root=PARTITION= in the config.txt file.
You are doing wrong if you try to define this in /boot/config.txt. You have to define the root partition in /boot/cmdline.txt and in addition the partitions must be defined in /etc/fstab.
On the latest unused Raspbian Stretch Lite image 2019-04-08-raspbian-stretch-lite.img you will find:
# cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=c1dc39e5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet init=/usr/lib/raspi-config/init_resize.sh
# etc/fstab
proc            /proc           proc    defaults          0       0
PARTUUID=c1dc39e5-01  /boot           vfat    defaulinit=/usr/lib/raspi-config/init_resize.shts          0       2
PARTUUID=c1dc39e5-02  /               ext4    defaults,noatime  0       1
After first boot with the image the option init=/usr/lib/raspi-config/init_resize.sh has been removed. This is done by the initial boot procedure and it is OK. But the option quiet should be still there if there was nothing done than booting. With the default entries from the image the SD Card should boot without limit. If quiet have also been removed then it is an indication that everything else is modifying your boot files and may cause failing boot the second time but missing quiet is not the cause. It only suppress boot messages on the screen.
Ingo
  • 42,961
  • 207
