I did recently an updated (sudo apt-get updated && sudo apt-get dist-upgrade) on my 3 raspberies. Two RPI 3B, and one RPI Zero W. The strange thing is that the raspberries that I installed later (a year later), have the newest kernel and bootloader, deb package version 1.20190401-1.
But my oldest Raspberry (3B) is stuck with 1.20170703-1.
sources.list on all of them is the same:
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Should I change some option in config.txt or something to get newer kernel? Both RPI 3B are version 1.2.
but have you also looked at /etc/apt/sources.list.d/raspi.list? Just this list contains
deb http://archive.raspberrypi.org/debian/ stretch main ui
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspberrypi.org/debian/ stretch main ui
and that is exactly the repository specifically for the Raspberry Pi containing kernel, firmware, drivers and other hardware related goodies. If it isn't present you can create it but before doing
rpi ~$ sudo apt update
rpi ~$ sudo apt full-upgrade
you should do a backup/image of the RasPi if you have important data on it. I don't know if there may come serious problems after such a long time without update.
If you have already updated from the raspi.list you may consider to reinitialize the package lists. How to do it you can look at Raspberry Pi sudo apt-get update not working.
Ingo
  • 42,961
  • 207
upgrade should get the latest, but the following will ensure this (and allow recovery from rpi-update)
sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel will get supported kernel/bootcode.
"In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 Even the rpi-update documentation now warns "Even on Raspbian you should only use this with a good reason. This gets you the latest bleeding edge kernel/firmware."
Run rpi-update :-)
See http://raspberryconnect.com/software-utilities/item/53-sw-rpiupdater for details and https://github.com/Hexxeh/rpi-update.
