I downloaded tge kali linux RaspberryPi 3 64 bit image from this site: https://www.offensive-security.com/kali-linux-arm-images/. The date of the image is 2019.1.
I burned the image on the sd card and it shows the rainbow image then it loads something but it never made it to the desktop. I don't use the SD reader on the pi because for some reason it doesn't boot kali but when I use the SD as a usb it "boots". I am stuck on a screen that it recognises usb ports, mouse and keyboard but doesn't show the desktop
Ingo
  • 42,961
  • 207
Andreas Paxih
  • 55
I had issues installing Kali to the USB too. I didn't have an SD card and so I had to fix it without one. It was getting stuck at the rainbow screen because it couldn't find the boot files. I fixed the issue by modifying cmdline.txt to point to my USB device partitions. I also had to change /etc/fstab to point to my USB device partitions. I've written a detailed guide here: How to install Kali Linux on a USB for the RaspberryPi?
Winston Jude
  • 139
You wrote you have a brand new Pi b+ so it's very likely it is a Raspberry Pi 3B+. This need updated firmware and drivers and it is known that other distributions than Raspbian haven't supported it very quick. You can look about this issue at Why am I getting a rainbow screen and flashing red PWR LED with a new Raspberry Pi 3B+?.
Please check if the kali linux image support the RPi 3B+. If the date of the image is less than 2018-03-14 it very likely that it doesn't support it.
Using first Raspbian and then putting kali linux back on will not help because the firmware/drivers are part of the image. Raspbian has two partitions. The first partition is the boot partition and is formated as fat. It contains the kernel, firmware and drivers to boot with. That is the part that must contain the updated firmware/drivers. The second partition is the root partition and formated as ext4. It contains the operating system. It may be possible that you also need updated kernel moduls from it.
Ingo
  • 42,961
  • 207
Ok something weird happend it was saying: attached scsi removable disk I unplugged the usb and added the sd on the sd rider directly without shutting down the RPi and it worked.
Andreas Paxih
  • 55
