Will it take the same procedure (like we install GNUradio in Ubuntu) or should we need something different. Please tell me in detail as i am a newbie on this side(Linux and raspberry pi). I am using Raspbian wheezy on raspberry pi.
Piotr Kula
  • 17,336
  • 66
  • 105
riki
I forgot to check, but it seems there is actually a package for gnuradio in Raspbian wheezy: http://archive.raspbian.org/raspbian/pool/main/g/gnuradio/
So you should be able to install the package by running:
sudo apt-get install gnuradio
If you want do develop using gnuradio, make sure to also install gnuradio-dev and maybe also the different libgnuradio* packages (you can search for them using apt-cache seardch libgnuradio).
Arne
  • 2,234
  • 35
sudo su -
echo "deb http://archive.raspbian.org/raspbian jessie main">>/etc/apt/sources.list
check if listed in source file
cat /etc/apt/sources.list
Get updates
apt-get update
install packages
apt-get install -y gnuradio
apt-get install -y gnuradio-dev
disable the the driver from using the USB DVB as a TV tuner card.
echo "blacklist dvb_usb_rtl28xxu">>/etc/modprobe.d/raspi-blacklist.conf
apt-get install -y rtl-sdr gr-osmosdr
echo 'SUBSYSTEM=="usb", ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="2832", GROUP="adm", MODE="0666", SYMLINK+="rtl_sdr"'>>/etc/udev/rules.d/20.rtlsdr.rules
Check if listed in rule file.
cat /etc/udev/rules.d/20.rtlsdr.rules
init 6
After the Pi reboots to test your device by running command.
rtl_test
