I've discovered again that cursing and swearing at inanimate objects doesn't actually improve things, so I'll try posting a question.
A couple of months ago I attempted a fairly ambitious project (Sonos Bluetooth Bridge) with my RPi that didn't work out. It was a fairly complex project IMHO, and as the author of the article didn't respond to help requests, I decided to set it aside, and start with a simpler Bluetooth project.
Connecting to a Bluetooth speaker seemed straightforward enough, but I'm now wondering if there is such a thing as a simple Bluetooth project. My setup is simple:
Just to verify the speaker worked, in about 2 minutes I was able to connected from my phone & play music. Speaker works.
Here's an attempt to show the relevant software on my system:
$ dpkg -l | grep blue
ii  bluez                             5.43-2+rpt2+deb9u2                armhf        Bluetooth tools and daemons
ii  bluez-firmware                    1.2-3+rpt7                        all          Firmware for Bluetooth devices
ii  pi-bluetooth                      0.1.10                            all          Raspberry Pi 3 bluetooth
ii  pulseaudio-module-bluetooth       10.0-1+deb9u1                     armhf        Bluetooth module for PulseAudio sound server
From my RPi, I used bluetoothctl to discover and pair with the speaker as follows (some steps deleted for brevity):
pi@raspberrypi3b:~ $ sudo bluetoothctl
[NEW] Controller B8:27:EB:67:85:55 raspberrypi3b [default]
[NEW] Device F4:4E:FD:2A:3C:B6 SoundCore mini
[NEW] Device A8:66:7F:4D:1A:B2 SdMiPhone
[bluetooth]# info F4:4E:FD:2A:3C:B6
    Alias: SoundCore mini
    Class: 0x240404
    Icon: audio-card
    Paired: yes
    Trusted: yes
    Blocked: no
    Connected: no
    LegacyPairing: no
    UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
    UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
    UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
    UUID: Handsfree                 (0000111e-0000-1000-8000-00805f9b34fb)
[bluetooth]# connect F4:4E:FD:2A:3C:B6
Attempting to connect to F4:4E:FD:2A:3C:B6
Failed to connect: org.bluez.Error.Failed
Research on the error led to zillions of matches, but the most promising appeared to a couple of answers given here on SE - @udjamaflip answer for Raspberry Pi. This answer refers to another answer on the SE Ubuntu site.. And one other answer on Unix&Linux SE.
I think I've followed the steps correctly. I've edited both files IAW the referenced answer, rebooted, used pactl, but I still get the failure:
FWIW, the pactl step succeeds once per reboot, trying to load-module again gets an error, but it can be unload-ed, and then load-ed successfully:
$ pactl load-module module-bluetooth-discover
20
Failure: Module initialization failed
$ pactl unload-module module-bluetooth-discover
22
The syslog shows the following for each attempt at a connection w/ bluetoothctl:
bluetoothd[491]: a2dp-sink profile connect failed for F4:4E:FD:2A:3C:B6: Protocol not available
Any ideas or suggestions are much appreciated.
Seamus
  • 23,558
  • 83
A possible solution is to add users to groups e.g.
sudo gpasswd -a pi pulse
sudo gpasswd -a pi lp
sudo gpasswd -a pulse lp
sudo gpasswd -a pi audio
sudo gpasswd -a pulse audio
Jim
