In an Android app that we created for a project (a step-counter fitness tracker), we require user authentication to access the user's data in Firebase. Same goes for the Python program in the Raspberry Pi.
However, I prefer to capture data from the LSM303 sensor connected to the Pi (which will show it to a tiny display that's also connected to the Pi), and send it to the phone, which will send it to Firebase (instead of having the Pi connect to the Firebase and authenticate), but I never got to figure out how to do it.
Here's the usb0 entry in /etc/network/interfaces:
allow-hotplug usb0
iface usb0 inet dhcp
I tried setting up a USB tethering, but it won't start.
$ sudo ifup usb0
Cannot find device "usb0"
Failed to get interface index: No such device
ifup: failed to bring up usb0
Raspbian info (if it helps):
$ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 9.8 (stretch)
Release:        9.8
Codename:       stretch
YamiYukiSenpai
  • 103
Your specific needs are unclear. Do you mean "communicate with each other" or do you mean "connect to each other"? To communicate you can use a WiFi access point in a managed network, the most common setup nowadays. How to do it you can look at Setting up a Raspberry Pi as an access point - the easy way or Access point as WiFi repeater, optional with bridge.
If you want to connect to each other device you have to use a peer-to-peer network. There are mostly two configurations for this: an ad-hoc (IBSS) setup or a WiFi direct setup.
The Independent Basic Service Set (IBSS) as a clean peer-to-peer connection is what it says: a basic service provided by every WiFi device compliant to IEEE 802.11. It is thought to be a base for higher communication protocols so authentication wasn't implemented for it from the beginning. It was expected that this is done by higher level programs like ssh, openvpn, ssl or so. Later WPA authentication was added to IBSS but I wasn't able to get it run on a Raspberry Pi. How to use an ad-hoc setup you can look at How to setup an unprotected Ad Hoc (IBSS) Network and if possible with WPA encryption?.
An often used setup for Android smartphones is WiFi direct. Although it is called p2p (peer-to-peer) it isn't really one. It is mostly used to dynamically connect mobile devices to static available devices (e.g. printer or server). How to setup this you can look at Setting up Wifi direct (wifi p2p) and DHCP server or p2p_group_add setting own password and ssid.
Now you can look what configuration fits the best to your setup.
Ingo
  • 42,961
  • 207
