I currently have kernel version: 4.14.79-v7+ (and I am using Raspbian Stretch)
pi@pi:~ $ uname -a
Linux pi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
When I try to update and upgrade my system the packages raspberrypi-bootloader raspberrypi-kernel get upgraded:
root@pi:/etc/kernel/postinst.d# sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  base-files bluez-firmware curl dirmngr gnupg gnupg-agent gpgv hostapd influxdb libc-bin libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev libcurl3
  libcurl3-gnutls libmosquitto1 libpam-systemd libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libssl1.0.2 libsystemd0 libudev1
  libwbclient0 libxapian30 locales mosquitto mosquitto-clients multiarch-support openssh-client openssh-server openssh-sftp-server openvpn python3-six
  raspberrypi-bootloader raspberrypi-kernel raspi-config raspi-copies-and-fills samba-common ssh systemd systemd-sysv tzdata udev wireless-regdb
  wpasupplicant
49 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 145 MB of archives.
After this operation, 810 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
The upgrade shows no suspicious warnings or errors (I omitted it here, as it is really long) and the returncode of the upgrade command is 0. BUT: The kernel upgrade was not successful as uname still shows the old version number.
pi@pi:~ $ uname -a
But if I have a look e.g. in /lib/modules, there are only folders for the new version
pi@pi:/etc/kernel/postinst.d $ ls -l /lib/modules
total 8
drwxr-xr-x 3 root root 4096 Mar 14 10:47 4.14.98+
drwxr-xr-x 3 root root 4096 Mar 14 10:47 4.14.98-v7+
I am not the first one describing this problem, e.g. in Linux modules mismatch version the same problem occurred. The threads solution (sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel) did not help me. But another user gave me a hint what might cause the problem: He also had problems because of his modified /boot/cmdline.txt. Mine is also modified, as my system is full-disc encrypted (I enabled the encryption like it was shown in this tutorial).
My /boot/cmdline.txt looks like this: dwc_otg.lpm_enable=0 console=tty1 root=/dev/mapper/sdcard rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait cryptdevice=/dev/mmcblk0p2:sdcard
Can anyone help me how to fix my problems, the problem is that after the upgrade I am not able to build my custom initramfs as I am getting the following error because my system is still looking for the old kernel files:
mkinitramfs -o /boot/initramfs.gz
WARNING: missing /lib/modules/4.14.79-v7+
Ensure all necessary drivers are built into the linux image!
depmod: ERROR: could not open directory /lib/modules/4.14.79-v7+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_ePmCvg/lib/modules/4.14.79-v7+/modules.order: No such file or directory
depmod: WARNING: could not open /var/tmp/mkinitramfs_ePmCvg/lib/modules/4.14.79-v7+/modules.builtin: No such file or directory
This is a huge problem because I use a very custom initramfs and as long as I am not able to build the initramfs my system will not boot correctly after the system upgrade.
Stefan Wegener
  • 297
Using an initramfs is problematic because it isn't supported by Raspbian and if the initramfs doesn't match the kernel version it will result in an unbootable system. This can occur when the kernel is updated but not the initramfs. This can also occur if only some modules/drivers are updated, not the whole kernel. On updates you have always to check what was updated and then renew the initramfs manual.
On a kernel update then the corresponding modules are also updated. Raspbian deletes the old modules immediately to save space but the old kernel is still running. The kernel cannot be swapped when it is running. You can only boot with the new kernel. Now you have the situation that you described, old kernel running but new modules installed.
It doesn't matter on reboot if you do not use an initramfs, but with it it's dramatic. The initramfs does not contain the new modules needed for boot up.
You have to make a new initramfs corresponding to the new modules before booting!
rpi ~$ sudo mkinitramfs -o /boot/initramfs.gz 4.14.98-v7+
I have tried to enable automatic update-initramfs. You may have a look at How can I use an init ramdisk (initramfs) on boot up Raspberry Pi?.
Ingo
  • 42,961
  • 207
