On Raspbian Lite I'm trying to run apt-get upgrade but running into following issue:
Setting up libssl1.0.2:armhf (1.0.2r-1~deb9u1) ...
dpkg: error processing package libssl1.0.2:armhf (--configure):
 subprocess installed post-installation script was killed by signal (Illegal instruction)
So I tried reconfiguring but that also fails.
pi@raspberrypi:~ $ sudo dpkg --configure -a
I tried running apt-get update, clean, reconfigure in a few combinations but always end up with the same issue. So I started suspecting it's the sources - but they look clean.
pi@raspberrypi:/ $ cat /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ stretch main contrib non-free rpi
Any suggestion what else to check are welcome. This is PI 2B+
jackrobot
It may be possible that your installation list files are broken. This files are downloaded when running sudo apt update. They can be found in /var/lib/apt/lists/*. You could delete and update them. But it is better to do it under control of the package manager. How to do it you can look at Raspberry Pi sudo apt-get update not working.
If it doesn't help you can try to reinstall
rpi ~$ sudo apt --reinstall install libssl1.0.2
and next step more aggressive
rpi ~$ sudo apt --reinstall --fix-broken install libssl1.0.2
Ingo
  • 42,961
  • 207
