I just started Raspberry pi and was ordered to get vim installed. However whenever I run sudo apt-get install vim
I get the following errors:
Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf vim-runtime all 2:8.0.0197-4+deb9u1 Connection failed [IP: 93.93.128.193 80] E: Failed to fetch
http://raspbian.raspberrypi.org/raspbian/pool/main/v/vim/vim_8.0.0197-4+deb9u1_armhf.deb Connection failed [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
So this time I run sudo apt-get update which works perfectly (unlike Ubuntu, typing sudo isn't asking me password)
Then I do sudo apt-get upgrade. which returns 83 errors, I paste here some of them:
Err:1 http://raspbian.mirror.net.in/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u8 403 Forbidden
and
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/b/base-files/base-files_9.9+rpi1+deb9u8_armhf.deb 403 Forbidden
Research from my side tells me that I should do this:
sudo rm /var/lib/dpkg/status
sudo touch /var/lib/dpkg/status
but I don't have any /dpkg in my /lib
Solution 2 that didn't work for me:
edit /etc/apt/sources.list and replace http://mirrordirector.raspbian.org/raspbian with a mirror address from https://www.raspbian.org/RaspbianMirrors (from the website: https://www.raspberrypi.org/forums/viewtopic.php?t=123260)
because my source.list file looks nothing like mentioned above, so I didn't messed with it.
